d60?
Discussion in 'The Garage' started by PsychoticDeadGuy, Aug 9, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i was at pick-n-pull yesterday and i thought i found a d60 because people on here said that they only use 3 ubolts...well i was looking at an axle with only 3 ubolts but the axle tubes were so skinny, it was about the same as my 10b...is that right? what size ring gear is in a d60 and a d44?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    What was it on? I think some of the old dodge Dana 44s had only 3 ubolts go figure. Did it have king pins or Ball joints that is the dead giveaway. Also a Dana 60 has like 3.5" axle tubes.
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    the tubes on the Kaiser M175 military pickup also had small diameter axle tubes plus a closed knuckle design...STAY AWAY!
  4. PsychoticDeadGuy
    Jan 8, 2005
    753
    one thing i havent really understood was the ball joints and kingpins...i dont know too much about the front axles yet...can someone post pics of the ball joint and the kingpin style axles so i know what i am looking for?
  5. sandawgk5
    Oct 28, 2003
    6,881
    This is a king pin axle notice how the steering arm bolts ontop where the ball joint would be.
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, so i am looking for those for bolts with the zerf fitting in the middle right? also, where is the "dana 60 bible" i have heard about?
  7. sandawgk5
    Oct 28, 2003
    6,881
  8. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    you should see : 60F on the housing (both front and rear)
