D60
Discussion in 'The Garage' started by 1987Blazer, Jan 21, 2007.
  1. 1987Blazer
    1987Blazer 1/2 ton status
    Apr 9, 2005
    168
    Murrieta CA
    This is probably a stupid question. Is there a seal or something that goes in the end of the axle tube nearest the tire?? What keeps water and dirt out of the axle tube??
    Also do I need to run the Oil deftector on the outer stubs??
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    there is nothing stock to keep water and mud out of the tube, right before the diff there is a seal to keep the diff clean, but there are some aftermarket one made to do what your asking about
  3. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Yes, you do need to run the deflector on the outer stubs.
    Jimbo
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Like 79 said, the inner seal does that... and also like he said, you can buy a set of the outer seals, which are an aftermarket option. I like to play in the mud & water a bit, so I went ahead and ordered a set recently. I bought mine from http://www.mad4wd.com . They have a shot of them on the main page, at the bottom. I figured it's just one more ounce of prevention so to me it was worth it. I'm sure not everyone see's it that way. But if I can make my inners eal survive that much longer, so much the better. It's most just a prefference thing.
