D60ff or 14ff??
Discussion in 'The Garage' started by BamBamblazer, Jun 14, 2003.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    I really need some input on this one. I just bought a d60 and d44 combo for a hellofa deal. I am concidering just using the d60 instead of a 14ff(which i dont have). This is gunna be in a dd which will see weekend wheeling, nothing very heavy. The spring pearches on the d60 are at 40" inside edge to inside edge so that is good.(right?) I know that 14ff is a little stronger but i just figure since i have the 60, why not? Ok so i guess what it comes down to is would you just use the 60 or would you sell it and buy a 14ff?????????
  2. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I sell it and get the 14 bolt, just cause you sell the 60 for a couple hundred and pick up a 14 for a 100. little extra money for you, but the 60 has better ground clearence
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    any savings is lost as soon as you want to lock the rear.
    If you can't find a 14BFF for >$200, your not looking in the right places....you'll save at least that when your Deee-troit is only $300 as opposed to $550 for the D60 Deee-troit
    plus, there is a reason even Ford guys sling a 14BFF under their rigs
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Like others said, depends on what upgrades you want to do to it. Not only is the detroit cheaper to install in a 14bff, you can probably do it yourself with out having to redo the entire differential. But if you are gonna keep it stock for a while I don't see any harm in using the dana 60, it should be plenty strong and hold up well. You don't have to run a 14bff just cause everyone else is. Of course I like mine... /forums/images/graemlins/grin.gif
  5. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    60 has better ground clearance, and u can gear lower than 5.13. Other than that, the ff14b is the better choice.
    j
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    j
    but why stop at a D60? A D70 would be a much better choice...
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Other than the cheap Detroit for a 14, the 60 has more locker and gear options. I would be happy with a D60....
  8. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    60 is a good choice if you have 38.5 inch tires or smaller for a weekend warrior. 14 bolt can handle 44's stock. like the other said it get expensive to build up a 60. so if your not going to put any money into a 60 or a 14 bolt might as well use what you already have.
  9. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Because he doesn't already have one.
  10. Suburbanite
    Suburbanite Registered Member
    Dec 1, 2001
    74
    Florida
    According to my "Chevy & GMC Pickup Performance Handbook" the 14BFF is rated for up to a 44" tire while the D60FF with 30 spline axles is rated for up to a 35" tire & D60FF with 35 spline axles is rated for up to 38"-44" tires. That's basically a quote. Don't ask me why the 35 spline version of the D60FF has a range of tire sizes bc I don't know & there wasn't an explanation given in the book. As a comparison the D70FF is also rated for up to a 44" tire.
  11. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    i guess because he didnt ask about a D70. /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif Personally, I think if you REALLY need the strength of a D70 and you are looking to run ratios lower than 5.13, you might as well just get rockwells.
    j
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Personally I like the 14 Bolt FF rear axle, but if you already have axles with matching gears, go ahead and use them. You could always swap it out at a later date if need be. Plus if you'd have too regear one of the axles to match the other, that'd be just another expence.
  13. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    he doesn't have a 14B either...
  14. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I think the 35 spline shafts are 1.5" while the 30 splines are 1.31".
  15. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Zakk, True, (and thinking local, which might be a mistake) but FF14B and 30 spline FF D60s go for the ~$. The D70HD go for more. At least every time I try to buy one they do. I've said it before, and a lot of people on here disagree w/ me, but if you're running a D44 or 10B than the FF14B isn't worth the the ground clearance you give up because you are limited by tire size by the front. I'd go w/ a SF14B or a D60 if you are going to run an axle w. 5-297 (760) u-joints.
  16. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What size tires do you plan on running? /forums/images/graemlins/thinking.gif
  17. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You can buy a spool for a dana 60 for under 200 bucks /forums/images/graemlins/grin.gif
    Dan
  18. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've seen rear 60's hold up to 44's for years. I say run it.
  19. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I would think that the book saying you should only run 35's with a 30-spline 60FF is rather conservative. One guy in our club has been running one of these axles for years with 39.5 Swampers and a big block with no problems at all........it's not a show truck either!
  20. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    I'd look around for a CUCV 14 bolt FF. 4.56 and a Detroit would be nice even if it would cost you a little bit extra.
