D60's are weak
Discussion in 'The Garage' started by 85mudblazin, Feb 4, 2007.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Well after a year of hard abuse I finally broke something.
    Was climbing a steap rock face and got the front passenger tire in a crack, gave it some gas and KERRPOWWW!!!
  2. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Is that a 30 spline or 35 :eek1: ??!!
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    35 spline:D
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    from his signature...
    rene
  5. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    cheap ass 35 spline shafts. time for an upgrade, no pics of where you broke.
  6. stockk5
    Apr 13, 2004
    2,037
    72
    Cromwell, CT
    u might as well just sell the rest of the 60 to me so i can just DD w/ it adn keep it safe. wont break hopefully then... hehe
  7. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    time for some cv's
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Yep im going Alloy USA shafts now. 10 year no questions asked warranty. Also throwing in some longfield joints. If I break that im going to quit wheeling:haha:
    Pictures?? We go wheeling not on a photo shoot:p:
    ALTHOUGH keep a eye out on the outdoor channel the break and some other wheeling will be shown on the superlift offroad show. They filmed my rig alot of times and got multiple interviews with me.
  9. RGV72BLAZER
    Jan 23, 2006
    2,425
    cool...i'll be on the look out for that episode. i thought wheelin naturally involved photo shoots...lol.
  10. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Get the recorder on stand-by ... :thumb: Make copies, cause you know you're going to wear the first one out. ;) Hope they use your stuff, Chris.
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    Probably didn't matter much. Its very likely the break was caused by the u-joint caps working their way out of the shafts. This could have been fixed by welding the u-joint caps or using full circle retaining clips (requires aftermarket shafts or machining of stock shafts).
  12. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Actually, Chris told me his caps were tacked.
  13. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Looks to me like the shaft failer at the ujoint portion. Were your wheels turning full lock or just wedged that tight in the rocks?
  14. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Whats in the diff?
  15. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    when the wheels are turned it puts more stress on the parts. Just like a ujoing on a driveshaft that has more angle on it, it will wear joints out faster. When turned, the amount of torque on the ears of the axle are alot greater and would make more since on why they broke. If the wheels where straight then That means that there was an even amount of torque on the shafts as there was on the joint. Meaning the shaft ears broke before the ujoints did. That shouldn't happen. That is why I am wondering if the wheels were straight or turned.
  16. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Chris drives like a mad man anyways. A year without breakage is amazing:thumb: :haha:
    I say you just put a D44 under their and go cruise the malls..........:p:
  17. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    If it aint broke, You aint running it hard enough. Good job on the breakage BTW:bow: . I haven't been able to break mine yet. New engine comming as soon as I get home though. I'll see if I can't fix that little problem:D
  18. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Tires were straight and I didnt have very much weight on the front end since I was about verticle on the ledge. The caps were welded in in 2 spots and that is why the joint is fine. Was just to much for the ears of the shaft. I know for a fact that the ears failed first as it shot them about 20 yards either way out of the truck:haha:
  19. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    should have just jumped straight to the chomo shafts first:whistle:
  20. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Before I saw the tagline, I suspected the diff was welded. Your Lincoln Locker broke your axles.
