D70 DRW to SRW. How much machine work?
Discussion in 'The Garage' started by mofugly13, Mar 28, 2003.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Found a dually Dana 70 at the junkyard today. What kind of machine work do I need to do to convert it to single rear wheel? I own a lathe, but not a milling machine. /forums/images/graemlins/usaflag.gif If I can do it myself, I might go back to the yard and make an offer. I don't know what the gears are, but they can't be worse than my 3.08 I have now. I have no ring gear up front so I've gotta buy new gears for that anyway.
  2. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Front or Rear?
    -fLeXy K20
  3. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Rear. Is there such thing as a dually front? /forums/images/graemlins/eek.gif
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well the fronts for dually trucks are different than fronts for non dually trucks so yeah there is a difference...
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Why mess with it you can pick up a 14 bolt for around $200 and slap it in.
  6. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    OK. It's a 2wd truck, but what would the difference be if I was talking about a dually front?
  7. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    the rotors on a dually front are different to make up for the uhhhh... i guess Negative backspacing? dont really know what word to use... ill see if i can find a pic
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    dually dana 60 front
  9. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    AHHHHHH! Thanks Bro! /forums/images/graemlins/usaflag.gif
  10. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    It can be done. You'll need to narrow the housing and buy cusom axle shafts. Take a look at the "New Pojects" page on my website. /forums/images/graemlins/wink.gif
  11. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    If your set on a Dana 70, then find one out of a late70's to early 80's single wheel dodge. They should have the beefy 35 spline axles and usually have either 4.10's or 4.56's in them. And yes you will have to move spring perches and shock brackets. I went with it because I wanted lower gears than 5.13's. /forums/images/graemlins/thumb.gif
  12. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Exactly! /forums/images/graemlins/grin.gif
    Edit: K5Drager, I just read your profile... how do you like the 5.86's and 38's? I'm close to putting together mine with 5.86's and 42's.
  13. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    I'll let you know, the maiden voyage is planned for Sat. April 12 as long as the cage is done in time. I'm trimming the fenders so I'll have enough room for 39.5 TSL's in case I want a little more tire. I'll keep ya posted /forums/images/graemlins/thumb.gif
