D70 Front question
Discussion in 'The Garage' started by SF87K5, Jan 15, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Has anyone ever heard of a D70 front axle out of a dodge W300? Everyone I know said no there is no front D70. Can someone help me please.
  2. SF87K5
    Oct 27, 2002
    1,105
    Dodge put a Dana 70 front axle in 67-78 trucks that where 1-tons or larger. They had to be ordered special from the factory.
    Took a bit of looking on the net and calling but I found my info. Thanks for the help guys.
  3. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    yes they did make D70 front diffs my buddy has one he was gonna put under an international it looks bad ass but the problem is that i think they all came drum brakes and if i remember correctly it had some type of burfields like a yota after looking at it i would just go D60
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    There is an open knuckle dana 70 out there. But there super rare. The closed knuckled drum braked ones are ones that I would pass on though. They have pretty small steering joints plus they have drum brakes /forums/images/graemlins/tongue.gif
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Stick to looking for a D60...the D70's advantage is in ring gear size, but I don't hear of many 60's breaking ring & pinion gears. The D70 came under some 4x4 RV's that are VERY hard to find.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    To my knowledge, any open-knuckle Dana 70 front uses Dana 60 outers and 35-spline shafts anyway... except for 35-spline stubs (but not usually).
    The bigger pumpkin hangs lower, so there goes some valuable ground clearance.
  7. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I saw a site dedicated to sand drag pickups. Most all of them were pre '60s and Lots of them had a D70 front end. Sand Pullers
