D70 rear, what ubolt & plates?
Discussion in 'The Garage' started by thor, Apr 5, 2005.
  1. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Those of you running 70s out back what are you using for spring plates and u-bolts? U bolts aren't so much the problem, I don't want to make spring plates.
    thanks,
    Thor
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I am running my old 14bolt spring plates w/ the holes hogged out a touch, and I got my ubolts bent up at that spring shop in Auburn/Kent right off of HWY 167... was under 40 bucks for 4 ubolts w/ washers and nuts.
  3. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    3 1/2" axle tube, same as a 14 bolt. The 14 bolt FF's use the under the axle spring plate, but the 14 bolt SF equiped trucks used the spring plate on top of the springs. The SF spring plates will fit your D70.
  4. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My D70 has a 4" axle tube, not 3.5...
  5. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Blue Torch Fab makes real nice spring plates (with the bent ends, like OE). I asked about making some for the 4" tubes and they said no problem, seems like they quotes somewhere around $45~$50.
  6. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    No It is a 4" tube.
  7. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Mine too. Mine are all 70HD dually axles ... don't know if that makes a difference.
    Eric M.
  8. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    A friend of mine drives a 99 f350 sd 2wd dually with the dana 80 & 4" tubes. His u-bolt plates are on the top.
  9. afroman006
    Aug 21, 2002
    2,876
    Oops, my bad :o
