D70
Discussion in 'The Garage' started by BranndonC, May 2, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i can get a d70 delivered for like 350 maybe 400 depending on shipping. what would the negatives of it be? i know parts cost a little more, but i really want ARB and 14FF dont have it so looking into d70, i'll do a search, but if you know about them please reply and give me an idea aobut them /forums/images/graemlins/smile.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    very comprable to a 14B. will allow for a ARB, which will solve your locker problem.
    perches and shock mounts will have to be totally re worked. AFAIK, there isn't a D70 that is a bolt in for a chevy. Also, IIRC, there are neck-down versions of the axles. ask the guy to pull the axles, snap pics, pop the cover and take pics.
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks zakk, i asked him, but i have no idea what to look for, but the people here can help me there. but i think a d70 is the way to go for me i like the fact that i can get ARB in there and dont mind the price diffrence, if all looks fine from the pics, i think i'll make it a go and buy it
  4. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    For starters there are a few different spline counts on the axles. I believe there is a 16,23,32, and 35, the best being the 35 spline. I think that most late model ford axles had the 32 but don't hold me to that. Make sure you know for sure what it is out of before buying parts as there where many different carrier styles with different ring and pinion offsets. The number on the axle will give you that info. And as previously stated the perches and shock mounts will need to be moved. Other than that its a great axle that is just as strong as a 14 bolt with different gear options and selectable lockers available. And yes you can stiil put disc brakes on and the 1350 and 1410 yokes are available for it just like the 14 bolt. Hopes this helps a little. Its just the small amount I learned building mine. /forums/images/graemlins/thumb.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    thanks Brent, i totally neglected the spline differences.
    IMHO, if it's not the 35 spline, move on. the 16 & 23 are not as strong and much older. there was something that made the 32's not as desirable (pinion, i want to say) but the 35's are good to go.
    *edit*
    if someone knows for sure on the splines please let me know. i am going off memoery here!
  6. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I think that the late model Dodges used the 32 spline 70's. The wierd part of the pinion is that some late model Dana 70's use a collapsable spacer ( crush sleeve ) for pinion bearing preload instead of the shims.
    I agree with the if it aint 35 spline than pass on it !
    There are a few different versions of the 70's so becareful. The most desireable are the "B" series and the H.D. versions. Stay away from the "U" series and the 70-3 versions. Good luck ! Tom
  7. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I am working with my HD70 now. The only BIG difference is that you will want to cut it down. The overall length from WMS TO WMS on mine is 73". Hit my webpage to look at some of the stuff about it. John Sweet has been a god send with info. about this thing.
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks guys, heres the small info about it:
    Dana 70 from 79 ford 1 ton. 35 spline HD 3.73 complete
    and he said for the price:
    $250 plus shipping
    probably about 300 lbs.
    that's about $100 for shipping via forward air.
    so i am really thinking bout getting this
  9. fr8train
    Aug 2, 2000
    1,712
    Maryland
    If possible get him to remove the drums. I dont kow about that 300lb. thing. Mine weighed a hell of a lot more than any 14FF I ever had to move.
  10. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    In the latest issue of Four Wheeler, there is actually a ARB locker listed for the 14 bolt in the drivetrain warehouse's ad. So I gues that they are actually producing one now.
    TRey
  11. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Is it for the FF or the SF?
  12. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    [/ QUOTE ] That's the width I'm looking for. Want to trade for an M1008 rear?
  13. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Pm'd you
  14. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    TRey
    I saw this in the petersens I just got the other day. it was for a 10.5" 14bolt (ff) and it was in the 4wpw add.... hmmm.......
    -Scott
  15. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    call and order it...then you'll see...
  16. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    prob for an SF
  17. SCOTTS_4X
    Mar 22, 2002
    129
    Modesto CA
    never seen a sf 10.5" ring gear
    -Scott
  18. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Sounds like you found what you where looking for. /forums/images/graemlins/thumb.gif If your going to go disc brakes you might as well have him pull those heavy drums to save on shipping.
  19. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    If its a Chevrolet rear its probably out of a dually dually rears are gonna look goofy because there to wide for a k5(or pu)body
  20. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    its from a 79 ford 1 ton so should the width be much wider than a 14FF ?
