D70HD question
Discussion in 'The Garage' started by SkysTheLimit, Aug 25, 2006.
  1. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I'm looking at buying b454Rat's set of dually D60/D70HD axles. Since this is the proper forum for tech questions, i got a few before I can buy them.
    To swap in the D70, will i need to relocate spring perches & shock mounts?
    Will H1 rims fit over the dually hubs on a D60 & D70HD without any mods?
    Any other gotcha's of which I should be aware? finally looking to ditch the 10bolts. I know I'll need the ubolts and spring plates and an appropriate yolk but anything else?
    thanks all.
    Chris
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    The only thing that I can think of is moving the spring perchs, 1 tons are 40 1/2" IIRC and 1/2 and 3/4 tons are 43 1/2". I'll check on the hummer rims, and then the rear driveshaft, either get a bigger one, or get a conversion joint.
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The H1's will fit unmodified with no problems, Boz42, MTMike, myself and a couple of others are doing this.
    Like b454rat said you spring perches will need to be moved. The shock mounts will need to be moved also.
    I got my spring plates from Blue Torch Fab (vendor here), IMO they're really nice. You might have problems with the brcke lines fitting as the banjo bolt size changed depending on axle and year model.
  4. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    Cool. thanks for the info. I'll probably just get a heavy duty driveshaft as opposed to a conversion joint. The shaft I have was cut for a 4" lift and now i have a 6" so i could stand to get a new one.
    Brakes... pfff :D
    thanks all
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Your driveshaft may still work. The pinion on the 70 is longer than 1/2 ton stuff so you might get lucky and just need the conversion joint.
  6. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Like others mentioned, you should have to move the perches and reverse the shock mounts. Shouldn't be any extra work going with a D70 over a 1 ton 14BFF.
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Yes.
    Yes:
    Hi-Res
    My D60 has a goofy-ass yoke on it and uses a 1330 U-joint. I just got a $16 conversion joint to go from my 1310 HAD shaft to the 1330 yoke on my D60. The rear 1350 worked fine, but you can also get a conversion joint for that too.
    The shock mounts needed to be relocated on my D70 too
  8. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    Thanks for the pics MTMike. I like your truck. you need some kind of plate for it about being an Avalanche's granddaddy or that Avalanches are for little girls or something. :wink1:
