d70s (front axle question)
Discussion in 'The Garage' started by tree_entz, Jul 26, 2004.
  1. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    i'm posting this for a friend since i'm much more often in front of a computer ( /forums/images/graemlins/rolleyes.gif).
    Berndog (remember the dude with the flying suburban) is making the big leap to the bbc (454) /forums/images/graemlins/grin.gif a well built one at that.
    along w/ the monster parts rig he got (i've gotta scan in some pics of this thing; 44s 6.13s) he got a set of dana 70s.
    anyone know if there is a x-over application for front?
    it's got the like backwards knuckle (tie rod on pinion side)
    ball/socket style
    anyone think it's worth it?
  2. tree_entz
    May 4, 2004
    141
    N. Vermont
    anyone????
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Closed knuckle 70 fronts are not worth it... The joints are weaker than 60 style u-joints and they weigh a ton.
  4. tree_entz
    May 4, 2004
    141
    N. Vermont
    that's kinda what I thought..... thanks!
    there's no conversion for that right??? you'd have to change the axle tube or something.
    The thing is fairly f'n old, like from a dump truck or something. looks pretty burley though!
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I would imagine you *could* convert it to the open knuckle design but it would cost a lot....although so does a stock 60 /forums/images/graemlins/thinking.gif
  6. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well you could press the tubes out of the dana 70 diff and then put in new tubes and dana 60 inner and outer knuckles and everything else... So basically you have to buy a complete 60 front to rob for it's parts. The only thing different about the dana 70 front open knuckle axles is that they ran 35 spline stub shafts, had the dana 70 center section with a slighly larger ring gear, and had slightly thicker tubes.
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    [HiJack] what comes with a D70 front? [/HiJack]
    /forums/images/graemlins/waytogo.gif
