daily driver help coolant leak
Discussion in 'The Garage' started by bad_bo_ti, Oct 20, 2004.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    my 92 geo storm has had a slow coolant leak for awhile, while i had it fired up today i notice a considerable amount of water comming out the exhaust, i would rev it up and it would spatter all over the driveway, there is also a lite appearance of white smoke. the oil is not cloudy/gray like water it leaking in there. could i have small head gasket or head leakand its not getting in the block? please help i dont need my 32+ mpg vehicle blowing up. thanks, chris
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    If it dose it after you have driven it for more than 10-15 miles i would worry, If that was seen on first start up of ythe day, more than likley it was condensation in the exaust and it goes away pretty fast. Anothe way to check is water in the oil and vice versa, but more than likley it was just condensation in your exaust
  3. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    try calling aoms local autoparts places or go to a local mechanic and have them block check it for you. it takes like 5 minutes. all they have to do is suck some air out off your radiator threw some type of fluid and if it changes colors then odds are you have a head gasket leak. or take it someware and get it pressure tested.
