Daily driver needs help
Discussion in 'Other Rides' started by sickquad, Jan 23, 2004.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    So, my girlfriend has a 92 Taurus with problems and I need some ideas.
    A couple of times she has started it and it started right up but there was no power to anything else, lights, dash, heat etc... So she turns it off and starts it up again and its fine, everything has power.
    A couple of times it has started fine and then died once she shifted from reverse to drive when backing out of the driveway. Then she starts it up and it is fine.
    This morning the same thing, it starts fine but no power to anything but the motor. She shuts it down trys to start it again and everything has power but it won't start. Plenty of juice, the battery is not low. No clicking sound when she trys to start it. It's as if the starter is dead now, not doing a damn thing. I'm not sure how to test the starter, need to buy a repair manual in the morning. Any ideas anyone? I don't even know where to begin on this. I would appreciate any help.
    -Chris
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Sounds like it may be in the ignition switch..
    John
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Ford had a recall on Ignition switches. Electrical not key.
    Ck with alldata enter enthusiast area. Use your vin and all sorts of problem for your car. It will list all recalls.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Sounds like it may be a Furd. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sounds like an ignition switch.. i had a newer style mustang not too long ago with the same problem.. ended up being the ignition switch and the slides that transfer the motion from the cylinder to the switch being dry and binding up in the runs on top of the column..
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have to agree with it sounding like it may be a fird
    we have a fuhrd taurus wagon about same year maybe hair newer in the garage and the freaking exhaust pipe manifold stuf flanges rotted real bad and studs all frozen bad, had to replace it all cuz seal was leaking
    those are different
    good luck
