Daily Driver?
Discussion in 'The Garage' started by dustinova, Dec 7, 2005.
  1. dustinova
    dustinova Registered Member
    Dec 6, 2005
    7
    Salem, OR
    How many of you guys use your k5's as your daily driver? I ask because I think I may want to do just that. Currently, I have a 1990 C1500. It's a great truck, but I want 4wd. I really like the look of the 73-87 k5's, and the 73-87 trucks. Plus, I would love not having to deal with a computer controlled truck (as a side question, what year did GM start using computers in the k5?) Also, suggestions on what setup I should go for would be very helpfull (motor, tires, lift, gears, etc...) Thanks for any help!!!
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    mine is my dd. i love it to death, jus wish the mpg was a little better, but considering its a big brick on wheels it does decent.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I DD mine since I got it in 2001 . My Blazer is an 83 , non California truck , so my truck has no computer . The fusebox has empty slots where the fuses would be though . I run a 1976 Nova HEI , and a electric choke Quadrajet :D
  4. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Think the first year for the TBI engines was '88, so the 88-91 K5's have the same electronic setup as your '90 truck.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    87 in the trucks for TBI . So it makes a 1/2 ton factory injected solid front axle short bed pickup a rare one year truck :D
  6. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    Why don't you want a computer controlled truck? Unless your gonna up the power past 280hp or so you won't have to touch it. Gm tbi is VERY simple and alot better than carb in drivability, low end torque, gas mileage, and off camber angles.
    For some reason alot of people think efi means you'll have to be a computer genius.
  7. dustinova
    Dec 6, 2005
    7
    Salem, OR
    Well, I'm not completely against the TBI setup. I love the setup on my current truck, even though it only has a 4.3 in it. I've been looking into how to performance modify a TBI motor, and it all sounds fine until you get to the computer. I don't have the time to learn all of the ins and outs of burning my own chips for it, and I don't know if I could trust some guy that I've never met to take the info I give him, and have him burn a chip for me that will perform as I would expect it to. Also, I've worked on Carb'd motors in the past, and they are very easy to tune, and upgrade. I won't need to worry about the motor running when the truck is at an extreme angle, because I won't do that to a truck that is my DD. Then there's the whole emissions issue. The computer controled trucks have a lot more sensors and what not to control emissions. I'm all for having a clean running vehicle, but all those sensors are just more places that the motor could give me grief. I've been chasing these issues on my current truck ever since I bought it. Thanks for the replies! Keep em coming!
  8. tin man
    tin man 1/2 ton status
    Nov 11, 2000
    149
    Roselodge Oregon
    Right now my DD is my 74. It is an old truck but, it hasn't given me a bit of trouble. When I was moving back home from Az., my wifes injected ford broke down 60 miles into the trip. It promptly went up on the trailer and the real truck :wink1: came down to get me the rest of the way to Or. It drove 1300 miles without a hickup. There isn't anything wrong with not being injected in my book.
    As for setup. When I had my 85 Blazer I had 36" tires, 410/14bolt, and a 4" lift. It was a good setup for me but, If you want to keep the gas economical, smaller tires are usually better.(especially if you have a stock gear setup.)
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    At 12 mpg my Burb would kill me as a DD. It's cheaper for me to have a car.
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    89 TBI Blazer DD. I commute about 50 miles a day. Love the TBI and 700r4. get 18 MPG no problem on the highway. Great gas milage off road. too. Would never trade TBI and go back to the stone ages for a carb. I do all my own work on it. I have a good running modified TBI engine putting around 220 HP to the ground according to my G- Tech. Acually I think TBI is very very simple to work on. Just need a scanner and the computer tells you what is or is not wrong with it. My k5 is a DD with 33s locked front and rear. So I expect it to run anywhere I put it. It had better get me thru anything I want to drive it thru off road, get me back home, then get me to work on monday. I thought thats what a DD was:dunno:
  11. buffblazer
    buffblazer 1/2 ton status
    Jan 5, 2005
    2,395
    Hudson Colorado
    my 86 is my dd it gets sucky gas milage with the bad running 350 and a 4 speed tranny so i get about 6 mpg but thats all gonna change because the engine is getting a complete overhaul
  12. dustinova
    Dec 6, 2005
    7
    Salem, OR
    So, if I wanted to put say 35" tires on it with a 4" lift, I should re-gear the rear end? Would 4.10's work fine? Would I have to re-gear both the front and rear differentials? This sounds like it could snowball really fast!
  13. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    the first year computers were introduced into the c and k series trucks was in 1985. these trucks have an electronic controlled carb that is a headache. if you get one of these plan on replacing the carb with a non electronic one
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i ran 3.73s with 35s for the longest time. never had a problem. i could still lay down some rubber on takeoffs. only thing was that you couldnt really use overdrive. 4.56 would probably be ideal. yes ud need to regear front and rear
  15. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I got rid of a 54,000mi. 99 GMC SLT Z71 on 38's after I bought my Blazer. It just sat in the garage because I enjoyed driving my K5 so much. I don't think you'll regret it, I know I don't. I would recomend driving one first just so you know what your'e getting into. I don't drive but about 20 mi. round trip to work so I don't worry with gas mileage. 10-12 mpg would hurt if I had a commute.
  16. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I just bought a 90 Burb to be used as a dd and a tow rig for my 91 Blazer. I dd the Blazer right now. I don't care about mileage.
  17. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    I use mine as my daily driver. The 454 and 40" Boggers only get me 4MPG though! But it's a fun 4MPG. Don't run Boggers though, big mistake, I'm shopping for new street tires.
  18. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    I have two 87's and I love them. They are totally reliable, make great power and get descent mileage (I am getting 14-15 on my stock rig and about 12 on my highly modified). I would suggest 87-91 for a DD. And if you do plan on modifying the TBI motor, there are a bunch of us here who have done it and we are here to help.
    PS. Mine is for sale in the classifieds forum if your interested!
  19. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    i drive mine 2 days during the week, and to run around in the evening and weekends:crazy:
    this morning it was a little cold though..
  20. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    gas is to $pendy for me to use my K5 as a DD... why not get a 5 speed 2 door metro for $500-1000 on craigslist and DD that? Seems like it wouldn't take long to make up that cost in gas money... 50mpg is the shizzel. :thumb:
    j
