dam u joints...xfer problem? help please please please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr.LaHoyaSunset, Aug 18, 2003.
  1. Mr.LaHoyaSunset
    Mr.LaHoyaSunset Registered Member
    Jan 25, 2003
    88
    Columbus Ohio
    alright, so in the past 9 months I have replaced both of the rear u joints, and now the truck is making the same dam shaky noise and vibrations that run throughout the truck that imply that the u joints are going bad... again. I do not believe it to be normal for these to go bad so quickly, I do not drive it over 3000 miles a week, and I am quite concerned.
    my questions is this, do you think that the transfer case is the cause? I hear a distinct clicking coming from around there when i accelerate, and my friend, whom i bought the truck from, believes that the seals are bad, and causing the oil to become nonexistent, and therefore ruining my joints.
    any advice would be greatly appreciated.
    Thanks a bunch y'all /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thinking.gif
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    What transfer case do you have? Have you filled up the xfer case fluids again to see what happens? You would have to have a pretty MAJOR leak to drain the xfer case. I'd fill it up and see what happens.
    Next... did you get greaseable or solid u-joints? If they are greaseable get them filled again w/grease and see where that takes you.
    Finally... if the joints really are shot for some reason... go to AutoZone. They have lifetime warranty joints for a decent price. At least that will help you out until you get the real problem resolved. /forums/images/graemlins/wink.gif
    Good luck!
    -Dan
  3. Mr.LaHoyaSunset
    Jan 25, 2003
    88
    Columbus Ohio
    Thanks quite much, I will give it a shot... of oil...
  4. ji240
    ji240 Registered Member
    Jul 30, 2002
    16
    East Haddam CT
    Also, if you find your u joints are going too quick make sure they are being installed properly. After they are installed, check to see if there is free movement in them. Many times people get them in and then just install the shaft. The joints should flop around freely with no binding. After you install them knock them back a bit against the clips. This way you are not putting undue stress on the needles.
    John
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Heh! /forums/images/graemlins/grin.gif Be sure to check back, and let us know what fixed the vibes you are experiencing!
    -Dan
  6. Mr.LaHoyaSunset
    Jan 25, 2003
    88
    Columbus Ohio
    so i changed the oil in the transfer case, and greased the grease fittings, and it still shakes like hell and clicks. im just gonna take it to the shop and see what the hell is going on..... hopefully it wont be too expensive....
    Thanks for your advice y'all /forums/images/graemlins/thumb.gif
  7. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    If your blazer is a 79 like your Bio says, you probably have a full-time t-case... right? If you do, the clicking could be the chain slipping in the case, which would not do anything to harm u-joints. Is your truck lifted? How much? Do you have a bad driveshaft angle? A little more information and somebody should be able to nail down why your joints are going south... I bet that a shop will try to nail you for some coin if you take it in... and thats no good.
  8. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    Mine did the same thing, I was going through u-joints like mad.I changed the driveshaft and the trans mount. It got a little better.When I pulled my truck apart to rebuild it I found the motor mounts were totally worn out.
    Check your motor mounts and tranny mount, these will cause vibrations if they are bad.
  9. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Try dropping the tcase if you have not done so. I have a 4" lift and had nothing but problems with the driveline. I purchased a rear cv driveline and the problem was worse. Maybe the shaft was bad...
    After spending 15 minutes lowering the tcase, my problem was instantly solved. At least it no longer vibrates and complains.
    Good luck
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No more lifetime u joints. 3 months for greasables, 1 year for non-greaseables.
  11. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Yea... I just bought a new set for the burb, and found that to be the case too. Sux. Thats ok though, for $13ea. I got new solid joints that still have a 1 yr warranty on them! ;-)
    -Dan
  12. Mr.LaHoyaSunset
    Jan 25, 2003
    88
    Columbus Ohio
    great news all, and you might just have to laugh at me.... that clicking noise was from the pumpkins.... i opened the fill bolt and stuck my finger in.... dry as a bone.... so i shot some gear oil in it, and shazam, noise gone, as well with the vibrations. all is now good, and i just drove it from columbus to wooster, and all is fine. Thanks a bunch for your advice, now all i need is a U joing grease gun fitting so i can shoot grease in the joints.....
    Thanks a bunch guys /forums/images/graemlins/smile.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    -Dan
    Yep. I don't use Autozone driveshaft u joints though. I get mine from the guy who built my driveshaft. He has Neapco HD u joints and Spicer. I used the Neapco HD ones last time because I was broke. They look to be a nicer design than the regular Neapco that AZ carries.
