damage check from hollister
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Jul 16, 2001.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i was wondering what the damage to everyones rigs were. i messed up two tires had a short and f-ed up my fan.
    Going nowhere everybody is a Moto Psycho
    Got my wheels in motion and i got a path to beat
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I broke my c-v joint and I think I got to much dust in my CD player. It won't eject the CD's...........Dan
  3. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    oh yeah i had that happen to my tape player too. and i got mud all over everything.
  4. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    I got my truck all dusty..... DAMN IT!
    Very dusty and dirty K5 sitting in my driveway!!!
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I never got to play in the mud.....So I think it is just dust....LOL
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I snapped the u joint on my drivers side front axle ,bent joint on the pitman arm end of my drag link,bent my tie rod and both tie rod ends ,I cant get my dam hood open cuz I crunched the bottom of my front fender on a big rock,and my rear license plate will never be the same.Im sure Matts list will be quite large.
    "I AM THE HILIFT KING"<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I got the into the mud pit half way up the doors and covered the left head light. Had to pull all the plugs after getting winched out by Matt (BabyBlue) to make sure I diden't suck any water in (a little came out when I cranked it), Than in the mud pit again it cought on FIRE! 3 Guys were on it with fire extinguishers withen 15sec (Estabon, me, and some guy we did not know). The fire was caused by tranny fluid being shot out of the dip stick tube onto the hedders. What fun!
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  8. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    oh yeah and i beat the hell out of my rear diff cover trying to go up tank trap.
  9. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    and i just missed it too. then there would have been 4 guys with fire extinguishers.
  10. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You guys make it home OK?????????? Dan
  11. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Well I got away easy. Just a dented gas tank skid and a dent in the pass side rocker, oh and two scraped pumkins!
    Hey my GreenHorn Gear swap worked GREAT!!!
    Thanks All!!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I made it home fine and AFAIK Matt did too. Mine actually did it under its own power! Estabon Had to get towed home from right before the grapevine (lost spark)
  13. baby blue
    baby blue Registered Member
    Dec 12, 2000
    93
    californa
    damage ? no damage escaped without a scratch. yeah right it wouldnt have been fun if i did not beat the hell out of my chevy thing.
    lets start
    1.first stuffed drivers side quarter panel
    2.broke drivers side front axle
    3.broke passenger side front axle
    4.broke passanger side warn hub
    5.the broken axle caused gear oil to leak all over the drivers side axle=crap brakes
    6.frayed winch cable
    7.dented passanger side door in
    8.stuffed the passanger side rear quarter panel in
    9.broke both rear tail lamps
    10.had a mud king?/mud crap tire blowout at 75mph
    11.broke a bead
    12.messed a rim up
    13.broke a rear side window
    14.bent door handle almost off.
    15.leakey air locker
    16.messed up new snow camo paint job
    17.bent rock slider
    cant think of any other stuff?
    babey blue
  14. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    1. One toasted 700R4
    2. Bent passenger front bumper
    3. Dented fender from bumper
    4. fuel pump died
    5. random scratches on the side from trees
    6. one smoked CB
    i think that is about it
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
  15. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Well I think all is intacked except to readjust float level in carb again.
    David
    [image]http://www.extremeblazer.com/sideapproachL.jpg[/image]
  16. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I just got a tweaked rear shock mount, a lot of scratches and a toasted coil or module. Not too bad.Oh yea I popped a bead and blew a collector gasket.
    <font color=blue>Esteban</font color=blue>
    <font color=red>SEMPER FI TO MY BLAZER
  17. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Oh ha, I got a cracked air dam, when gold rush pulled me out when I got stuck trying to pull those idiots in the toyota out...........LOL
  18. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Not quite the same but all the dust from doing donuts messed up my (Neon's) trunk lock....! BTW Any pics of that?
    Hey Matt I got most of your right tail might sitting right here... well pieces of it... you want it back? LOL.... [​IMG]
    I also found a couple lug nuts in Tank Trap, part of a broken tow hook, valve stem and a part of what appears to be a Ford door handle.... any takers of this stuff? [​IMG]
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  19. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    man you messed up alot of stuff. lets go do it agian. next time i'll do the trail with you. i just didn't want to wear out your winch any more than i already have. yeah thats it
  20. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I didn't put my Blazer thru the gauntlets like you guys did. I only got a few pinstripes from some trail brush, and a chip in the windshield from a flying rock thrown by an 18 wheeler while on the way home.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
