damaged 350 link to pics added
Discussion in 'The Garage' started by georgiared84, Apr 29, 2003.
  1. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Just wondering. I just helped my brother in law take his 350 out of his 72. The engine threw a connecting rod through the oil pan and siezed up. what I want to know is, is the block worth anything as a rebuild project? (Machined and bored out of course) I haven't had the oil pan off yet. It's the original 72 4 bolt.(checked numbers) just wondering if it'd be worth it to strip and send to the shop or just scrap it.
    OK, here's two links to pics of the motor. I think with some duct tape I can reuse that oil pan. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    http://coloradok5.com/photos/showphoto.php?photo=5728&password=&sort=7&thecat=500
    http://coloradok5.com/photos/showphoto.php?photo=5729&password=&sort=7&thecat=500
    http://coloradok5.com/photos/showphoto.php?photo=5737&password=&sort=7&thecat=500
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Re: damaged 350
    If it was mine i would still send it in and have it checked just to know if it was bad . But why did it throw the rod?
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: damaged 350
    It won't cost anything to take it apart providing you do it yourself. (Just don't mix up the main caps and get them out of order. I like to use a punch and number them just to be sure befor I even bust the bolts loose.) Pull it apart and see what shape the block is in. If it's good, you can get a crank kit,( might aswell build a stroker ) crankshaft, connecting rods, pistons, ...ect. and build a motor. It'd be worth saving to me becouse I build myown motors, and used to have a friend at a machinne shop that would swap work for me for something I could do for him. Worked out pretty good, I'd get machine shop work, and he'd get me too pull and install motors/trannys, or whatever he didn't have time to do himself.
  4. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Re: damaged 350
    Not sure yet. he's not the best about maintenance. He got water in the distr. and cleaned it out. Ran like crap every since and I figured he got the timing off. I don't know when the engine was rebuilt, but I do know that it was rebuilt once in it's life. It's still standard bore. He was going to throw it out so I figured I'd at least do a visual check on it and have it magnafluxed.
  5. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Re: damaged 350
    Actually 383 was exactly what I was planning. I just got a 305 back that I dropped off 3 weeks ago and I am supposed to be picking up a 400 block 2 bolt the week after next. (haven't decided what to do with it yet. Thinking about stock setup with it .) i did a favor for one of the guys at the shop so he's doing a couple of blocks for me. He told me if I do a stroker the only thing he'll charge me is the extra work on the bottom. I'm not planning on working on the 350 for a couple of months, just wondering if it was worth the shop space.Wasn't sure if there was anything I wasn't thinking of. I know when a rod get's slung you want it to go through the pan and not somewhere else. If I do the 383 the only thing I need is the caps and block anyway. Now I've got to figure out what to do with these when I'm done. One's got to go in my 83 shortbed. (probably the 305 so I can sell it. I got away with pretty much just a bore on it.). Either the 350 (If it's good) or the 400 is going to the guy who rebuilt my trans. He's supplying the kit and heads. He's putting it in his versionof a pickup lead sled.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: damaged 350
    Pop off the oil pan and inspect the cylinder walls from the bottom side. When a 350 of mine broke a rod, it made one hole in the oil pan and another hole in the cylinder wall. /forums/images/graemlins/eek.gif
  7. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Re: damaged 350
    Thanks, I'll check. It put a nice set of dents and holes all through the pan.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Re: damaged 350
    Let us know what you find. Stuff is still getting slung all around the engine after it throws a rod. There are still 7 cylinders working to spin the crank... /forums/images/graemlins/eek.gif
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: damaged 350
    We like pics of carnage, hint hint.
  10. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Re: damaged 350
    I'll put one up this weekend. I've got to go get the engine from his house.
    BTW, we got it pulled without incident (except for having to leave the torque conv. attached to the engine due to not being able to turn the crank. Got it on a pallet up on it's back. He's taking a few brackets he wanted off it and the thing tips over. He tries to catch it and gets a nice slice between two fingers on his left hand. 13 stitches. /forums/images/graemlins/ignore.gif After all the chances that truck had to get us while we were taking loose frame brackets, etc... it waits until we are done! /forums/images/graemlins/shocked.gif
  11. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
  12. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Re: damaged 350
    I know why the rod went, that engine has never had an oil change! Look at that sludge /forums/images/graemlins/eek.gif
  13. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Re: damaged 350
    Yeah, I found that out when I pulled the pan. I mean I expected to see the metal in the oil but the oil was like the crap you drip out of the bottom of a coffee pot after you have left it on all day. Oh well, He's the one paying for the new crate motor. Do you think he'll start listening to me about reg main...? Not a chance!
  14. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    The red paint gives the illusion that it was shot by a shotgun and is bleeding.
  15. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Re: damaged 350
    he better listen /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    12496962 502ci/502hp Deluxe Big Block Engine Kit $6,995 /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
    (Fully Assembled)
  16. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    Re: damaged 350
    /forums/images/graemlins/eek.gif* ooooo ahhhhhh...droool*
  17. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Re: damaged 350
    He's not getting that ambitious. Just a regular old gm crate 350.
  18. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Re: damaged 350
    its still gonna hurt
