damaged hardtop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pshackles, Feb 20, 2002.
  1. pshackles
    pshackles Newbie
    Feb 20, 2002
    3
    I just bought my first blazer an 87. The carpet was wet and so was the back seat. I removed the whole interior. took a garden hose and sprayed all along the seals, they weren`t leaking. but the top had moisture, I looked on the top and there are little holes in the hard top where water is getting in. has anyone had this happen? and how did you fix it?
  2. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    I dont know how to fix that one but, if you go to a junkyard you can usually get old k5 tops for like $20. (atleast around here)
    '85 k-5 gmc jimmy 4x4 sierra classic. '84 k-5 gmc jimmy sierra. '70 cuda 440 6 pack executive edition shaker hood, steering column shift.
  3. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    fill out your profile that way we can get more info on your rig and know a little about you.If you have holes in your top eather use fiberglass resin or silicone in the holes <a target="_blank" href=http://mikes77k5blazer.rockcrawler.com> my k5</a>
    1977 k5-blazer4"pro comp lift 3.5 in rear dana 44,12 bolt rear, 350 &amp;,205 t-case,465 trans,flotech headers and mufflers<P ID="edit"><FONT class="small">Edited by mdm365 on 02/20/02 11:54 PM.</FONT></P>
