damaged Inner shafts? (Pic)
Discussion in 'The Garage' started by Zeitler, Jul 10, 2005.
  1. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    I'm about to install new inner axle seals ..but
    will these shafts ruin the new seals?
    don't know where on the machined part the seal rides..?
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    The shiny spot.
    clean em up. maybe polish them up a bit more so they are smooth and won't tear up the seal.
    Lube up the seals with some oil or grease before you slide the axles in. ;)
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    clean it up with an emery cloth strip.
  4. Zeitler
    Feb 22, 2005
    99
    i have tried to clean em up a bit but the pitting is deep..
    now what?
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I would buy new shafts, and keep those as spares.
  6. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    other choices..
    They may have "speedi-sleeves" available for those axles,they give a new smooth surface for the seals to ride on...also you can buy "Repair" wheel bearings that are offset a bit so they ride on the unworn area of the axle,and they are a sealed bearing that does not require the OEM axle seal...but for ultimate strength off road you may prefer to get a better set of axles that have no pits or wear.. :crazy:
