DAMN ALT wont stop slipping, what to do????
Discussion in 'The Garage' started by VisionxOrb, Nov 7, 2003.
  1. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    ok I figured out the problem with my bad voltage from my alt. the belt is slipping but making no noise. its glazing over though. i realized it from being under the hood and hitting the throttle and watching the voltage drop and smelling somthing, at first I thought it was the alt smelling but i disconected its plug to collapse the field and all of a sudding the thing started spinnging faster i mean alot fast ( no the engine ) as its own fan whine got about 6 times louder and higher pictch. I though "thats wired" and pluged it back in with the engine high an noticed the voltage was at 14.6 and then dropping as the alternator got quiter and i looked closer an could see that it was slowing down eventhough the engine is not so. the smell must be the belt and its tight, made it tighter but no go, what can i do?????????????
  2. Sounds like the bearings are seizing in the alt. making it hard to spin. If you disconnect the belt on it and spin it by hand is it hard to spin? You'll probably need to replace the alt.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Replace the belt. Once it's glazed over you wont get a good grip. That's what I'm doing tomorrow night before I head off to badlands /forums/images/graemlins/smile.gif
  4. VisionxOrb
    Oct 10, 2001
    251
    Newbury Park, Ca
    The bearings are fine, actually the thing is only like a month and half old at that, im gonna replace the belt but I dont want it to happen again is the thing.
  5. bigmike72
    bigmike72 Registered Member
    Sep 30, 2003
    74
    SoCal
    Should probably get a new belt. When you tension it up make sure that it has a 1/2 in deflection along it's longest run when pushed with your thumb (I usually just eyeball it but you can use a ruler). You may have had it too tight which could have fried the belt.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    actually could be your battery dying. You said your alt was new. When your battery needs charging your alt senses it and it acts like a brake with the magnetic stuff going on inside there and starts putting out voltage. If your battery is drawing more than your alt can put out then it will really draw and make your belt slip. My brother's truck just went through this very same thing.
