damn alt
Discussion in 'The Garage' started by stiches, Nov 28, 2005.
  1. stiches
    stiches Registered Member
    Nov 16, 2005
    72
    vallejo/lodi, CA
    Hey as before i got a belt problem....
    history
    changed out the alt got one from kragen
    new belt
    Now when its cold out side it squeaks...its not tight or loose to me its right...i had my machainc check it out he said might be faulty alt but i want to see what u guys say first
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    There is this stuff that is belt dressing, a spray on lube for squeeky belts. Don't use too much tho. haha. You also might want to check the alignment of the alt with the rest of the pullies. A bent or misaligned bracket can cause this as well as wear and tear on bearings, belts etc...
    Hope this helps.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Go for a good quality gates or similar belt. The cheapies are usually thinner and more prone to the "chevy mating call." My v-belt squeeled on and off all summer until I bought a better quality belt. Constant tightening didn't eliminate the squeel for very long with the cheap belt. BTW, I've got a serpentine belt system in the shed for a spring install...
    I don't like belt dressing. It does help a little tiny bit, but can make a HUGE mess. AND, in my opinion, its nots fixing the problem...its another temporary fix.
  4. 87350blaz
    87350blaz Registered Member
    Oct 23, 2005
    33
    New Mexico
    Mine is queaking but only at a certain RPM and if i get i wet (like run thorugh a puddle) it goes away :confused:
  5. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    don't know about that...here is what i did to fix my problem....used belt dressing...checked the alighment...and use a prybar to make sure its good and tight...the only way i can see it squeaking is if the alt is faulty...might want to go have it check out...unless someone has a better soulation
