damn bearings
Discussion in 'The Garage' started by blzn1, Dec 11, 2002.
  1. blzn1
    blzn1 Registered Member
    Apr 9, 2002
    76
    SO-CAL
    Anyone else going thru front inner and outer bearing frequently. (once a year)
    I was talking to a friend, he also said he went thru alot of bearings on his blazer. What gives?
    Rick
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Sounds like a damaged or improperly installed bearing race or out of round spindle. Once per year is not normal.
  3. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    What you using it for? Could be a lot of things. Are the races in right? doing a lot of water or mud crossings, Torquing the spindle nuts right? I know, that's all obvious stuff, but otherwise I'm not sure. I replaced my originals at 130K miles and they were still good but I've usually cleaned and repacked them after sinking past the hubs in water or mud.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    How are the bearings damaged? Pitted? Overheated? Water in the grease will pit the surfaces of the bearings and races. Installing the bearings too tight can cause overheating. Also be sure that you are packing the grease into them correctly. The spaces between the rollers should be full of grease before installing the bearings.
    BTW, front wheel bearings should easily last 150,000 miles. /forums/images/graemlins/shocked.gif
  5. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    Probably over tight spindle nuts. the inner nut is supposed to have like 0 ft-lbs on it ( i make mine just hair past hand tight ). the tighten the snot out of the outer nut. works good for me so far.
