Damn DMV (exhaust and smog issue)
Discussion in 'The Garage' started by sandawgk5, Jan 15, 2007.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I gotta get my K5 tested at a test only station. Not really a big deal as the one I always go to is a test only. Problem, last time I smogged I barely passed my HC was 1 below the limit and Nox was kinda high. Question, my exhaust is hammered as in aft of the cat there are many holes in the piping. Can this be one of the culprits to my high readings? I think I also need a cat as with the muffler not really in the system the exhaust is pretty quiet:o. The engine does not smoke or use oil could changing the exhaust from the cat all the way back be a reasonable fix for my problem? I also dont know if there is a shop local that can dyno smog a lifted vehicle with 37s:o. Oh all of my smog equipment is installed and functioning properly.
    Ira
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Having a bunch of holes in the exhaust will mess up the readings.
    Fix the exhaust, Change the oil, maby a tuneup you should pass.
  3. sandawgk5
    Oct 28, 2003
    6,881
    I am pretty sure my HC is from a bad cat but the other readings are what got me thinking about the holes. I think there is some scavenging effect that is pulling outside air in and screwin up the readings at the sensor. I do plan on changing the oil and running a bottle of water absorber (alcohol) I cant remember the brand name we ran it on our boat when I was a kid and I will let it idle in the parking lot while I wait on the guy to put it in the bay.
    Ira
  4. dyeager535
    26,979
    If you are pulling in outside air, it would lower your PPM of whatever pollutant they are measuring, lowering the readings of said pollutant. (assuming only after O2 sensor/converter leaks)
    I know here locally they won't test if they determine you've got exhaust leaks.
  5. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Catco makes a good high flow cat that'll get rid of the pancake style that's in there now. 3" Flowmaster from there back.
  6. Slapperbar
    Nov 29, 2005
    2,747
    3
  7. sandawgk5
    Oct 28, 2003
    6,881
    I am getting a cat and super 40 from Mudfrog on here in the 3" variety and all my tubing will be from summit as they have the best price I have found so far. My intention is to use ball socket couplings in front of the cat and aft of the muffler to make a 3 piece exhaust system. Summit also has a universal tailpipe kit that is mandrel bent 3" aluminized. The price of all of the supplies is less than what a shop wanted to charge me for doing the pipe with me supplying the cat and muffler. I still need a welder so that will increase my overall cost but in the long run it will pay off:D. When I go with my 56 fronts I will redo the Y pipe with all mandrel bent piping but I will have to wait on that as I will have to piece it together out of mandrel bends and I want to get some time behind the welder before I start that.
    Ira
  8. sandawgk5
    Oct 28, 2003
    6,881
    If they are not a "test only" station I cannot use them.
    Ira
  9. Slapperbar
    Nov 29, 2005
    2,747
    3
    You can use them to get your A/F right. They sniff under load and idle.
  10. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    This is easy, just move to Illinois. They just passed a law and now no vehicles pre-OBDII (older than 96) have to go for emissions testing. SWEET!!
  11. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    Just ship it to me. No smog no problem.
  12. sandawgk5
    Oct 28, 2003
    6,881
    I found my old smog data sheet. Tell me what you guys think. I also did not let it idle in the parking lot:doah:.
    Ira
  13. Slapperbar
    Nov 29, 2005
    2,747
    3
    I think letting it warm up would help. But what do I know.
  14. sandawgk5
    Oct 28, 2003
    6,881
    The wife just told me to go ahead and order my exhaust stuff and then said "this better ****in make it pass". I also get my welder :D. Millermatic 135 and a 40 CF bottle of Argon/CO2. I am still looking for a good place to buy my bottle it seems like $170 for a new bottle with 10 year cert and full with argon /CO2 mix. Is that a fair price for a bottle?
    Ira
  15. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    If its the orginal 20 yr old cat, you will definetely see improvement with a new one.
    Not only warm it up, make sure the oil is fully warmed up also. Take it out on the freeway and don't shut down until after the test.
    One of my previous times, the tech clued me into State O' CA allows for +or- 4* of timing error. Hint; retard it to 5* or 6* instead of 8* BTDC.:D
    Oh, and a bottle of "Guaranteed to Pass".
  16. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
    old stock cats did only 1 -2 conversions of crap. the new cats do 3 conversions. much better cats .
  17. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    New cat should fix that right up. Remember that welding aluminised is not like the steel we did for your bumpers and winch mount.
    It welds like butter. I can think of nothing that is easier to weld.
  18. Slapperbar
    Nov 29, 2005
    2,747
    3
    Get a bottle from gasspro or airliquide. You kinda perminantly rent/borrow for refills.
  19. sandawgk5
    Oct 28, 2003
    6,881
    I can buy an empty brand new from Stoody (a local welding supply shop) and fill it for $22 a pop for 40 SCF. I think that is the way I will go. I like the fact of owning my own bottle.
    Ira
  20. readymix
    May 30, 2004
    6,706
    26
    What are you goin to do for a cart? Build your own?
