damn gauge
Discussion in 'The Garage' started by the fall guy, Mar 10, 2005.
  1. the fall guy
    the fall guy Registered Member
    Jul 1, 2004
    35
    Hey guys....I was just wondering if you had the same problem with your gas gauge and how to fix it.(85 k5 ) When I fill my tank the gauge reads 3/4 tank...then 1/2 then3/4 again. It's all over the place. then when I first start it up it reads empty then after a while goes back up. I'm thinking it could be my gauge but could it be my sending unit (floats are out of whack) I know that if it reads full out than the sending unit is done but this one has got me confused:confused: :confused: thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    flaot could have a hole in it, or its the sender unit regulator wire winding bad
    hell might even be a corroded connection at sender
    good luck
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Isn't the float just a buoyant piece of styrofoam?
    The sending unit isn't that compicated of a device, it's just a rheostat. Just make sure the little brass tab is making firm contact throughout it's travel. You can also check it with an ohmmeter. Should read 0 ohms at one extreme and 90 at the other.
    First I'd also check to see if there's a short on the sending unit wire somewhere along the frame rail.
  4. dyeager535
    26,975
    Does the gauge "bounce" when you drive over bumps and what not?
    Went through that on mine recently: bouncing gauge is a gauge problem, incorrect readings are going to be sender. (as in never reading full)
    Grounding the sending unit wire to the frame SHOULD peg the gauge out, which will test the gauge. Really need to pull the tank/sender to test the sending unit through the full sweep of the float arm.
    There is a post about "fixing" the sending unit on the board, should be able to search and find it. It improved the accuracy of my fuel reading, but didn't completely solve it.
    The sending unit float is a *styrofoam-like* material. If it wasn't bouyant, it would be consistently erroneous.
  5. goldwing2000
    goldwing2000 Guest
    Styrofoam melts in gasoline... :whistle:
  6. dyeager535
    26,975
    Well whatever it is, (I know styrofoam is buoyant, not sure what to call the material) it's bouyant, and looks/feels like styrofoam. Getting a hole punched in it probably wouldn't affect its operation. Post fixed.
    I believe the implication was that the float was a brass float or something like that, when it is in actuality a bouyant material.
  7. goldwing2000
    goldwing2000 Guest
    Just giving you sh!t. :D
    It's probably a urethane of some sort.
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Actually, the float in my 89 blazer is a brass float and so was the one in my 76 blazer.
    I'm not saying there aren't floats made of something else but mine were both brass.
  9. dyeager535
    26,975
    I just looked at two Saturday out of a '91 V3500, both plastic.
    Three TBI ones I have (87-91) all plastic.
    One that came out of my '81 tank, plastic.
    All GM A/G-body ('78-88) car ones I've ever seen (10+) plastic.
    All later ones I see here are also plastic. (not that you can ever trust aftermarket)
    Not trying to start anything either, it's just that I've had more sending units out of "newer" (meaning 70's-80's) GM vehicles than I can count and I've yet to see a brass one.
    I'm surprised no one else has chimed in. Maybe we need a poll. lol.
    If you've seen what you've seen, thats proof, right? :) Heck, I've never seen TBI fuel lines that didn't use threaded connections, but others have. Can't say they are liars.
