Damn rear shock mounts
Discussion in 'The Garage' started by oldassjeep, Jul 1, 2005.
  1. oldassjeep
    oldassjeep Registered Member
    Oct 21, 2004
    84
    Burnet TX
    Anyone have a good fix for the sucka$$ excuse for the upper rear shock mounts on 2nd generation K5's. I have replaced both the shock bolts and now they have come loose again. The driver's side has cracked the mount!
    I thought about making a crossmember and then relocating the mounts on the axle inward.
    I would like to hear if anyone else has had this issue. If so what did you do to fix it. I tried seaching but couln't come up with anyspecific info on this problem.
  2. dyeager535
    26,980
    Pretty much everyone at some point has this issue.
    My theory on the problem with them loosening up/tearing the mount off the frame/tearing the mount itself is that the stud starts to loosen just a bit, which allows the shock to hammer the mount every time the suspension moves.
    I got a new shock stud, and had it welded to the mount. I just didn't use those crush nuts that bugger up the threads.
    GM knew this was a problem, later on the studs are press-in serrated, like a wheel stud.
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
  4. chevy_addict
    chevy_addict 1/2 ton status
    May 4, 2004
    138
    You are here, I am not
    I welded a piece of 1/8" steel to the shock stud and then welded the 1/8" steel plate to the shock mount on the frame to help re-inforce the frame mount and put on the nut on the back side.
    Dave
  5. 83-6.5TD-BURB
    83-6.5TD-BURB Newbie
    Jun 30, 2005
    San Antonio TX
    i need to fix mine now, had to get new tips for the welder though. i am thinking about making a cross member setup though. seems like a good setup
