Damn rusted cotter pins.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SuperUnknown, Aug 3, 2001.
  1. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    I have a rock rod ready to slap on the Jimmy, but I can't get the old rod off. The rusted old cotter pins will not come out. Dose anyone have any tricks or tips for such a thing?
    It's ok to love your truck.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    If they are rusted it will be easy to shear them off. If you have an impact just run them off like any other nut and it should come off. If you dont have air power then just take a big wrench and turn the nut off or a socket with a big breaker bar. LIke I said, if its that rusted then it should be weak enough to shear off.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Totaly second BB62's reply. Air is a good thang!
    Twiztid
  4. RockBurb
    RockBurb 1/2 ton status
    Jul 30, 2001
    106
    Moscow Idaho
    What I did the last time that I had this happen was straighten out the pin on the end and then I broke it off as close to the bolt as possible. I then took a pin punch and pounded it out. Worked like a charm.
    84 Burb with 35's and locked front and rear.
  5. johnnysjimmy
    johnnysjimmy Registered Member
    Apr 23, 2001
    47
    Air power or pure muscle just twist until its in your hand!!!!!!!!
    73' GMC Jimmy 8" lift and 35" tires.....14 boltff and big 10 bolt on the way
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Ditto - when all else fails, use brute force[​IMG]
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
