Damn Squeaky Springs!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Oct 29, 2000.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have a Procomp lift (That SUCKS) right now, and the springs in the front make a loud squeak when I hit a speedbump or a bump in the road. How can I get rid of this sound?
  2. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I have the same problem. I've thought about putting a water proof grease between the leafs. Don't know if that will work or not. Any other ideas?
    blazen91
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    The only thing that gets rid of the squeak is when I wash the springs with water!
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Do your springs have the poly bushings? Mine does the same thing and I have the poly bushings in my front springs.
    I wonder if it could be dis-assembled and greased? I was going to take mine apart and sand the springs smooth, paint them and see if I can find some teflon strips to put between the leafs. I would also grease the bushings if I could, maybe even just the bolt that goes through it.
    Mine also quiets down when the springs get wet, thats why I thought it might be the bushings.
    Rene
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    ORD sells greasable bolts for poly bushings so you don't have to disassemble to grease them. I put some marine grease between my old leafs, and it made the ride a little better for a few days and it might ahve squeaked a little less, but I don't remember.
    90K5
  6. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    If you get some graphite impregnated grease or teflon spray greaser you disassemble you spring bushings and recoat the bushings. I would do with greaseable spring bolts for later useage.
