Damn Wipers!! ****UPDATE****
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Nov 19, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    They still go one by themselves. I've replaced the motor,and the arm on the column. I just ordered a new switch. My question is where is the wiper switch on a 84 with tilt style column???
    Well I replaced the switch in the steering column,and that was the problem. They work agian YEEAAAA!!!
    What a way to spend the day off /forums/images/graemlins/angryfire.gif
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Re: Damn Wipers!! *HELP*
    I think that is caused by dirty contacts in the 'park' mechanism. It's been a few years since I had mine apart though./forums/images/graemlins/crazy.gif
    Rene
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    so I take it that the switch is in the top of the column? I need to take the steering wheel and all the other crap off? Ugh... /forums/images/graemlins/rolleyes.gif
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    yeh mine does that too, whenever i have the wheel not in the bottom two slots, it just sucks cuz i gotta look over the wheel to see the top of the speedometer but atleast the wiper dont work, try puttin your wheel in different positions and see if that changes it. It did on mine, and ive gotten used to the low wheel.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I hate to be the one to tell you this, but there's a chance that you have a short in the wiring in your steering column.
    One of the first problems I had with my K5 long ago was "ghost wiper syndrome". Every so often, my wipers would come on for no reason at all. The problem became more frequent, and one day while I was driving I had the pleasure of witnessing a smoke show from behind the steering wheel. To make a long story short(no pun intended/forums/images/graemlins/crazy.gif), the coating on a couple wires at the pivot point in the column had worn off, causing my wiper issues. They ended up shorting out against eachother and frying the entire wiring harness in the column.
    You don't want to hear this, but I would recommend you tear into the column and take a close look at all your wiring.
  6. UseYourBlinker
    Jun 7, 2000
    11,117
    ****...the same thing happened to me. I bet that is what happened. I did see smoke come from the steering column. /forums/images/graemlins/angryfire.gif
  7. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    That wiper switch has the wiring harness, that runs the entire lenght of the column, attached to it. So whether it be the actuall switch, or the wiring, the new switch w/ harness should fix your problem.
  8. Can Can
    15,552
    136
    The same harness powers your cruise control. If your truck is equipped with CC and it doesn't work either, chances are the problems lie in your wiring.
    Keep your chin up, brother. I'm sure that right now you feel like your avatar, eh?/forums/images/graemlins/wink.gif
  9. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    damn, thats where my Cruise control went!
  10. UseYourBlinker
    Jun 7, 2000
    11,117
    Update.. read original post! /forums/images/graemlins/rotfl.gif
  11. nofeartruckin00
    Oct 5, 2001
    798
    Glad to hear your ghost wipers went away finally! /forums/images/graemlins/thumb.gif
