damnit no! Help... please please please help...
Discussion in 'Pacific Region' started by Topdown, Jan 6, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Check vacuum lines first, since you said it ran great a day or so ago............then timing, make sure it didn't move on ya. Electric choke? Make sure it is getting good voltage. Keep us posted. /forums/images/graemlins/laugh.gif
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check for a intake gasket leak as well /forums/images/graemlins/eek.gif
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    other than that stuff, make sure your distributor is tight. /forums/images/graemlins/thumb.gif
  5. Topdown
    Nov 26, 2002
    2,598
    the distributor is tight and hasnt moved... timing appears to be set between 7 - 8 degree's so that hasnt moved either.
    Its wierd, like its starving out whenever I stand on it...
    from idle to 1/2 throttle it seems to be fine.
    I called a carb place today and left a message, hopefully they/he will call me back and be able to get it in.
  6. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Screw that, bring it to my house, I'll fix it, all you need is 3 bald monkeys on meth with 5 gallon buckets of starting fluid under the hood, pouring them straight into the manifold...Works for me... /forums/images/graemlins/ignore.gif /forums/images/graemlins/thumb.gif
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Always werks fer me too /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  8. Topdown
    Nov 26, 2002
    2,598
    uh, no?
  9. T-ROY
    T-ROY 1/2 ton status
    Dec 3, 2002
    468
    Orchards, Wa
    Rob, Have you ever thought of changing your name to "Crash Test Dummie?"
  10. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    A few details will help.
    Q-jet?
    same distributor?
    Same condition when at operating temp?
    The engine is fairly new so we can sorta rule that out.
    With the distributor cap off can you move the advance easily?
    You should be able to move the roter and it will snap back to position.
    Sometimes the distibutor will get gummed up and be stuck in all the way advanced.
    There are a few lil things that will give ya grief.
    Carbed engines are so much easier to fix and make run right.
    There are so much less things dictating on what will make it run right than on an EFI system.
    Although once ya understand how and what makes an EFI engine operate it is all pretty simple realy.
  11. Topdown
    Nov 26, 2002
    2,598
    new carb, same relative operating temp (other than it being fricken cold outside, the engine runs at the same temp) I will check the distributor tomorrow (hopefully)
  12. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    have ya tried pouring a can of heet fuel stabaliser in the tank?? mabye u got water in the fule or some bad gas??? just a thought....or cause its so damn cold the fuel is trying to freese....
  13. Topdown
    Nov 26, 2002
    2,598
    tried heet and got fuel at different locations (3 tanks - 3 different places)
    Its at the carb shop right now... I can deal with most stuff, but carbs are over my head.
