Dana 20 and 70 into blazer?
Discussion in 'The Garage' started by gm guy, Jan 5, 2006.
  1. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    I just picked up a 63 Jeep dually that has a T-18,??? t-case, Dana 20 rear, and Dana 70 front.
    I've been told this is a closed knucle front end. What does that meen?
    [​IMG][​IMG][​IMG][​IMG]
  2. gm guy
    May 1, 2004
    151
    Sorry for the crapy pics I'll get better ones so hopefully someone can confirm that these are dana 20 and 70 axles. Could I use the 20 for a sigle wheel in rear or only dually? Can I buy wheels that fit the axles or are they obsolete. Good score or waste of time and money?
  3. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    That shifter is awfully long! Anyway, you need redo the pic post. Stack 'em vertically instead of horizontally.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Chances are you have a Dana 70 rear and a Dana 20 front. If it is a Dana 20 front that is what CJ had in them I think not good for a 5K rig. There are a few guys on here that run Dana 70. You would have to change the spring perches and shock mounts but you have to do that with most.
    Ira
  5. gm guy
    May 1, 2004
    151
    Thanks for the replies. So are there wheels available for these axles?
  6. sandawgk5
    Oct 28, 2003
    6,881
    They look like they would be the standard 8X6.5 bolt pattern. Wheels available in all diameters from 15" up to 22".
    Ira
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    There is a Dana 20 transfer case but no Dana 20 axle.
    I have never seen a J-truck dually before. Anyway, closed knuckle means that the front ujoints are encased in little balls on the ends of the axle, and the knuckles pivot on these. I highly doubt that has discs on the front, so my advice would be to just forget about this swap.
    However, what kind of winch is that on the front? you could probably make that work.
  8. gm guy
    May 1, 2004
    151
    Thanks for the replies. i'll part it out or sell it to get $ for my Blazer!!
  9. gm guy
    May 1, 2004
    151
    Okay it's a Dana 70 rear and a Dana 44 front the trans is a T-18 4 speed. Anyone know anything about these?
  10. gm guy
    May 1, 2004
    151
  11. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    parts for the 70 and 44 are everywhere. Strengthwise, the 70 is pretty much equilivant to a gm 14bff and the 44 is about that of a 10b. Good rearend, decent front but if its closed knuckle, id stray away from that...plus you should have a 44 or 10b up front in your blazer anyway. The rear swap could be worth the time and money, id forget about doing anything with that front end...
    As for the trans, i don't know much about that sorta stuff...i know a little about gm autos, but thats about it.
  12. gm guy
    May 1, 2004
    151
    Thanks that helps. It looks like this thing is going to sell as a whole!!! More Blazer $!!
  13. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    There is a big following for the J truck duallys, You can recover what you have in to it. IMHO, I agree with the other inputs that it is not a good doner vehicle for a K5. Keep looking.
  14. jason m
    jason m 1/2 ton status
    Feb 12, 2005
    173
    holland mass USA
    transmission is a T-98 model 20 ( dana ) transfercase, rear dana 70 found in the j3000 and 4000 trucks, all fronts are dana 44's. where are you located very intersted in some parts or hole truck depending on location, jason.
  15. gm guy
    May 1, 2004
    151
  16. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Being a 63', Dont know for sure but the 44 front is prob. closed knuckel with smaller u-joints. The 70 rear is prob. a low spline count axle. Niether axle is a desirable unit under a fullsize chevy. I say sell the truck/ parts to some jeep freak as this is an un-comon truck and the funds could go to cool mods/ parts for your k5
  17. gm guy
    May 1, 2004
    151
    Thanks, I've gottena bunch of interest so far fromt he Jeep freeks so i should be selling it pretty quick. My blazer will be getting the lift I want and hopefully the 35's!!
  18. OnetonCowboy
    OnetonCowboy Registered Member
    Sep 1, 2005
    29
    TX
  19. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    trans is wanted by many bronco owners as it is a good manual swap trans umm otherwise i dunno when i had a bronco i was looking for one but it is since long gone
