Dana 24 TC - any good?
Discussion in 'The Garage' started by mouse, Nov 10, 2005.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    A buddy of mine found a divorced ford dana 24 in the junkyard this week. It operates smoothly and is in great shape. Looks very similar to a 205. We have been discussing the possibility of using this with his 241 to produce a "doubler" setup with two cases. Any thoughts?
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    What type of vehicle will it be in? If drivetrain length isn't an issue I don't see why it couldn't be done. I don't know if that Dana 24 will do it, but I had an old Ford that had a Dana 21 two speed (read hi/low) xfer case that had a 2 low between Neutral and 4-low, I think. Its been a while.
    Kris
  3. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    The truck he's thinking about dropping it in is a 1964 sub thats sitting on a shortened 1976 truck (4x4) frame. We discussed possibly going with a drivers side-drop axle (jeep or ford) up front.
  4. mud390
    Oct 31, 2002
    1,210
    If you were going with a driver side drop, it wouldn't be that hard to find an axle, not around here anyhow. Usually cheaper too. If it would fit, I don't see why not trying it. Take a few measurements. Seems like all you'd really need is a crossmember, a half shaft to connect the two xfer cases, shifter/linkages for the second xfer case, and obviously drive shafts.
    Kris
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    How would you connect to the 241 ? Would need a plate with a seal of some sort to keep the fluid in the 241 .
    What can be done , if supported bt bushings and not hard mounted , is a passenger drop 208/241 , directly into a drivers drop 32 spline 241 . You just need to have connecting tube/adapter made with the round pattern on both sides . The 208/241 have a 32 spline output for the slip yoke that slides right into a 32 spline input .
    Ask Marv , he did it :D
  6. mud390
    Oct 31, 2002
    1,210
    If the 24 is divorce mounted, all you would need would be a super short drive shaft between the two cases, correct? Thats how the divorced 21 on my old was setup from the factory.
    Kris
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    there's one on eBay right now, they look pretty stout. I have a divorced NP202 and am thinking about doing something similar.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You have to work out how you're going to couple the 241 to the Dana 24 ....splined sleeve?
    IMO, test it's torque-handling first in a longer rig where you can run the 241 and 24 with a driveshaft between them. (Before investing in some kind of adapter arrangement).
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The 241 is female on the input , and without the adapter in front of it , fluid would come out .
  10. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    The idea is to keep it divorced. As a matter of fact, we discussed using just a single u-joint between the two cases. Any movement between the two would be bad, but the 241 uses a slip joint and would allow a little movement. Basically mount the two together without an adapter - a "poor mans" doubler.
    There's no problem fabricating the crossmembers, etc. We also have the original stub shaft from the donor vehicle ~early 70's ford.
    I'll have to measure, but I think the jeep 44 is narrower than the chevy. I'll be looking at parts today.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Maybe I wasn't picturing it right then , you are putting the 241 first ? that would work with the slip yoke and a u-joint then :D
  12. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Exactly. He is definitely not afraid to try something new. Should be interesting if he goes that route!
  13. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    There are at least two different track width FSJ D44 front axles. The wider one is about the same width as the '73-'91 GMs. Seeing as how you have the wheel base to do it it souds like the cheapes way to get a doubler. A short drive shaft with the stick slip yoke would be perfect. I'd use an NP205 for the second case, though. Sounds like any easy way to save about $2000. (no need for a doubler and 3:1 range box)
