Dana 30 front disc conversion.
Discussion in 'The Garage' started by jk3078, Sep 2, 2006.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Ok, so I have a dana 30 front, open knuckel, drums brake, and I have a dodge 44 front with discs. Would it be possible to use the outers from the 44 to convert the 30 to disc? They bolth have the 5 on 5 bolt pattern. Thanks and sorry for the Heepy ?'s.:eek1: :doah: :( :mad: :haha:
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    No.... you're talkin' about a 72-76 brake drum D30...right... :dunno:
    The knuckes are different.
    You'd need to find a 77 and newer D30 eqipped w/ disc brakes.... Used to be rare to find these laying around, but not so much anymore since everybody goes fullsize or bigger anymore...
    No worries....... I'm a closet Heep guy too - just nobody knows it cuz I drive a Marvzda.! :D
    Marv
  3. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    That is sorta correct but with the wrong explination. THe knuckles are different but interchange. They use the same Ball joint and will swap. The trick becomes the Ujoint. Your D30 uses a 269 joint and the D44 (if post 73) uses a 297 ujoint. So you have the option of running the pre 73 chevy or dodge stub shaft with the D30 269 Ujoint or buying aftermarket inner shafts that use 297 joints in the D30.
    This is the process the jeep guys use to run high steer.
  4. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Wow.... ! Good info... Learn somethin' new everyday!
    Thanks 6.2puller..
    Marv
  5. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Thanks 6.2, I have this stuff laying around (the 44) and was hoping to be able to "sweeten the pot" on the jeep rolling chassy I have up for sale.
