Dana 300
Discussion in 'The Garage' started by tomseviltwin, Nov 9, 2003.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Hey, why not? 4:1 kit available and 32 spline output.
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    It was originally designed to go behind anemic engines in light weight vehicles. That being said, you can build one that will probably survive in a full size application, but with anything, if you throw enough time and money at it, it will work.
    They never came behind any GM tranny, so an adapter will be a must. I think they range somewhere aorund $300 from AA.
    The gears in these t-cases aren't near as strong as a NP 205, 203, 241, etc. or any full size t-case.
    On the plus side, they can be had for about $100-$200, are shorter than many t-cases, especially a slip yoke model, and like you said, 32 spline REAR up grades and 4:1 kits are available for not too much coin. It is rumored that someone is coming out with a 32 spline front output upgrade, I have yet to see one so I am not sure.
    Bear in mind, people do still break these t-cases, even with aforementioned upgrades. It will not be an Atlas or Doubler. Search the PBB for anything you might want to know about these t-cases. MANY people on there run them with good results. I am currently building one for a customer with all of the goodies you listed, plus flipping it for a driver's drop and throwing on a twin stick.
