dana 44 1/2 to 3/4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Sep 22, 2000.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    can a dana 44 1/2 ton be turned into a 3/4 ton? and is that a good front end to run with a 14 bolt FF in the rear?
    From the Grave to eat the Jeeps
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>That is a good axle combo. I have both of those sitting im my driveway waiting for the TSM brake stuff to get here so i can get started putting them in my truck. The only difference in the 1/2 and 3/4 44s is the brake backing plates, hubs, and rotors. Heres a link to a post on ORC where someone is selling the backing plates cheap http://bbs.off-road.com/wwwthreads//showflat.pl?Cat=&Board=offroadforsaleother&Number=219476&page=0&view=collapsed&sb=5. </font color=blue>
    http://www.chrisd71k5.coloradok5.com <font color=blue></font color=blue>
  3. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    its basicly the brakes and the hubs? thats the differance? its not the ring and pinion or the axel shatfts?
    and is it better than running a dana 60 up front?
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Yes, the only difference is the brakes and 8 lug hubs. A dana 60 is way stronger then a dana 44 but they're expensive, heavy, and take up a lot of clearance.</font color=blue>
  5. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Most Dana44 R&Ps are the same as long as they are in the same carrier range. Exceptions are (Ford front) reverse rotation units and (Jeep & Isuzu rear) aluminum center units. All GM carriers are the same within each range. The only real differance is early K5s and 1/2 ton trucks used a smaller u-joint. After about 74 K5s, 1/2 tons, and 3/4 tons all used the same u-joint. It is also the same one used in the front 10 Bolt.
    Jim '80 GMC.
    It's a Wheelbase thing, You're Jeep wouldn't understand!
    http://www.bigjbear.coloradok5.com
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    He's right about the only diff between a d44 1/2 and 3/4 is the backing plate, spindle, and brake stuff.
    I've heard the corp10 bolt is the same as a d44 from the knuckle out. Anyone done this?
    -- Mike
  7. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Did you get your rear Detroit BigJBear?
    I sent you an email about Currie, was wondering if you got your Detroit and got it installed for the Dixie Run?
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
