Dana 44/ 10 bolt interchangable?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Jul 9, 2001.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Does any one know if the hubs, bearings and rotors from a '84 10 bolt work on a '73 dana 44? Also, can this axle be swapped into a '84 k5 without moving the spring perches.
    Thanks,
    Ray
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Everything should work fine. Spring perches are the same.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Make sure if you use the hubs, rotors, backing plates from the '84, you use the spindle too. Your '73 spindle is an older design and uses smaller wheel bearings. It won't work on the newer parts. But if you reuse the '84 spindle with everything else, you will be just fine.
    You will have no trouble with the perches. Matter of fact, you can use a Ford front axle, too! And some Dodges. Just the fact that many other different vehicles have the same distance between perches, makes for some pretty interesting swaps for those who want to be creative! [​IMG]
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    " Does any one know if the hubs, bearings and rotors from a '84 10 bolt work on a '73 dana 44? "
    No they will not. BIG NO.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok wise-ass, now why won't they work? Tell me in your specific words, your best explaination why they won't work? Don't forget who you are talking to! [​IMG]
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Well, I'm still waiting for your explaination Executioner.........
  7. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Yeah.. we're all waiting...
    Wes is the guru on all this...
    Ray.. we shouldn't have a problem finding your axles tomorrow... ton's of 4x4 trucks around here in the salvage yard..
    I even know where a rough country 4 inch lift kit is!!!! On a truck in the wrecking yard we're going to !!!! [​IMG].
    A well armed society is a polite society.UPDATED <A target="_blank" HREF=http://www.rocko.rockcrawler.com>http://www.rocko.rockcrawler.com</A>
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I just did this swap with an early 44 and a late model 10 bolt .I swapped every thing from the knuckles out off of the 10 bolt and bolted it to the 44 knuckles.The 44 knuckles I used have the tie rod go in on top.It makes the tie rod a few inches higher.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    He's probably busy fixing the factory posi in his front 12-bolt axle.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    [​IMG] ROTFLMAO!!!
    Or, he is probably busy looking inside the differentials with that $200.00 scope!!! [​IMG]
  11. Executioner
    Feb 22, 2000
    1,530
    I think you already answered it in your post !
    73 used a smaller inner bearing, therfore the hubs have different races, as well as the spindle .
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Go reread my post again!!! I told him to reuse the spindle from the 84 along with the other stuff!!! I explained to him the smaller bearing on the 73, THATS WHY I TOLD HIM TO USE THE 84 SPINDLE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  13. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    now now children can't we all just play nice, besides with a big enough hammer you can make anything fit together!. BTW wes, Since you say dodge front ends have the same distance as a chevy, does this mean I can bolt a Dana 60 front end from a dodge right into my blazer for the most part?
    You call that dirty!?
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have never messed with a Dodge axle of any sort. Just from what I have heard, some will bolt right in, but the D60 is something that really needs to be explored. I have heard the perch differences are minimal. Some have said they bolt right in, and some others have said they were a tight squeeze to get in. I really don't know how much difference there is compared to a GM D60. I do know some other members on this site are running Dodge D60's under their trucks. To find some answers and solutions to this question, make a post on this forum and see what kind of mixed reviews you can get. Believe me, you WILL get some mixed reviews! [​IMG]
  15. Executioner
    Feb 22, 2000
    1,530
    Sure, I'll reread,but only if you will !
  16. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    thatk30guy, I've heard the Dodge spring perch location is about 2 inches off. No big deal on the passenger side, but the driver's side spring perch location is a part of the housing. I imagine with a big enough hammer and a small enough brain it could be forced together, but I wouldn't want to drive that truck.
    -- Mike
    <font color=blue> At some point I'll be done building my truck and can actually go wheeling. Until then, I guess sex and alcohol will have to do. [​IMG]
  17. thatK30guy
    Jan 12, 2001
    32,076
    55
    What kind of reply was that?
    You must be illiterate. You always reply in short answers. Whats wrong? Cant read the long answers or replies?
    Why should I have to reread my post? I'm the one who made the post. DUH! Give my your phone no. and I will read that post OUT LOUD to you!
