dana 44 1350
Discussion in 'The Garage' started by crowley, Jul 15, 2004.
  1. crowley
    crowley Registered Member
    Oct 26, 2003
    24
    Phoenix, Az
    is the 1350 spicer yoke the best possible or are there bigger yokes available?
    but if there arent, the 1350 would still be a wise invesment right?thanks
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Depends. 1350 is stronger than 1330, but 1330 runs at more angle. 1410 is stronger still, and has good operating angle.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    to be totally honest on a D44 I wouldn't waste the money on going to 1350 unless you are going to build a serious rock rig. Even a mild to moderate rig should be ok with 1310's and a D44. The axles and axle ujoints are probably still a weaker link then the 1310's.
    Harley
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I have seen 1310's blow dana 60 stubs so in the front they should be fine. Jesse at HAD can set you up with the 1350's if you really want.
  5. crowley
    Oct 26, 2003
    24
    Phoenix, Az
    thanks for the input! the dana44hd is what i have to work with right now, im just tring to decide if i should build a kick ass d44 or for just get the d60, their just spendy.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Build the D44 within reason. Drop in a locker, HD tierod, maybe crossover, good locking hubs, and call it a day.
    What do you plan on wheeling? Rocks? What size tires? If so you need to go wheeling with the crew here in AZ sometime. You might be convinced D60's aren't necessary.
    Harley
