Dana 44 and 10 bolt caliper question
Discussion in 'The Garage' started by rotten03, Apr 12, 2004.
  1. rotten03
    rotten03 Registered Member
    Nov 11, 2003
    23
    Carterville, IL
    I apologize if this has been asked before but I couldn't find anything on the search page. I have an '89 1/2ton Suburban and I'm in the process of swapping in a 14bff and a D44. The discs and calipers are pretty bad on the d44 and I was wondering if any of the brake components from my old frontend will swap onto the d44. I appreciate the help guys.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, assuming the D44 is 3/4 ton to match your 14 bolt FF rear, you WON'T be able to re-use your 10 bolt rotors. The rotors of a 3/4 ton are larger, but they aren't that expensive to replace.
    Now, you CAN use your calipers from the 10 bolt on the D44, and in fact I recommended it because you won't have to mess with banjo-bolt size problems, and you won't have to bleed the brakes (assuming you don't disconnect the brakeline from the caliper).
  3. rotten03
    Nov 11, 2003
    23
    Carterville, IL
    Awesome man, that's exactly what I wanted to hear. I knew I could deal with the rotors, I was mostly concerned with the calipers. Thanks for the advice.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Is the D44 front from a 3/4 ton?
    Because if it's like the 10 bolt, you may need new back plates also, when you go with the bigger rotors of the 3/4 ton, the backplates are a little larger to bring the caliper out more to make room for the larger rotors.
  5. rotten03
    Nov 11, 2003
    23
    Carterville, IL
    Yeah the D44 is a 3/4 ton. Oh I have another question. The lockouts aren't like anything I have seen. They arent manual and they dont look like automatics. Is there a 3rd option, like fulltime lockouts or something? The end doesnt stick out like manuals, it's more like a cap and thats it. I guess I'm gonna have to switch them. Will the lockouts from my 10 bolt work on it?
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If you mean just a stamped metal cap, it s from a truck w/ an NP203, ie full-time 4WD. The internal lock-outs will swap.
