Dana 44 and 35" tires
Discussion in 'The Garage' started by 80blackgmc, Nov 27, 2004.
  1. 80blackgmc
    80blackgmc Registered Member
    Nov 21, 2004
    43
    Dana 44 and 35\" tires
    Hey guys. Just wondering, is anyone running 35" or larger tires on their Dana 44s, and if so, what is reliability like? Thanks guys.
  2. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Re: Dana 44 and 35\" tires
    I am running 38.5 on my dana 44too big a tire tore up the ring and pinion and spider gears. replaced the gears until I can afford a good dana 60. You should be OK if you have the right gearing I'd say 3.73 and lower.
  3. dvldog 70k5
    dvldog 70k5 Registered Member
    Nov 7, 2004
    38
    So Cal, West Coast
    I had the same question a little while back and pretty much all agree you'll be just fine, but most recomend no going any larger on the stock axles unless you upgraded to a Dana 60. Your best gear option would be 4:56's for 35's.
    Nick
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I beat the piss out of mine with 35s, never broke.
    Bolted on the 38.5s and broke it the same weekend.
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i run 35s on my 10bolt and never broke anything, yet.
  6. 80blackgmc
    Nov 21, 2004
    43
    Well, I bought the truck used with a blown motor with dana44/14 bolt. It has 38" super swampers. I had some junky 33s, so I put them on, drove it, put new 35s on, got crazy in the deep snow (stuck), and broke the stock axle. Got a spare from the local boneyard, replaced it, somehow snapped it again without even knowing. THEN, I took the diff cover off, found broke 4.56 gears, but broken from before since there was no broken parts in the diff. I just had the diff rebuilt with new 4.56 gears, all new bearings and another junkyard axle (got two now for spares and a nice, complete D44). I also got new hubs this time around, and the others were kinda cheezy/bent. I could only turn the hub on 1/2 way last time, maybe that is why the junk broke.
    Hope it lasts with 35s, 4.56 gears and normal street mostly driving.
    I looked for a complete, reasonable dana 60 but could not find one. I'll eventually find a 1 ton 454/dana60/14 bolt truck.
  7. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Here is my old 10 bolt with 40s at Uhwarrie, a axle will live as long as you let it.
  8. 80blackgmc
    Nov 21, 2004
    43
    The second time i broke the axle, I never noticed it. First time I locked the hubs, went to move in the mud, could not, checked the diff when I got home, and was broken again. I figure hubs....and this is why i decided to just rebuild it completley...
  9. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    42" swampers on my locked 44 with 4.88s. I'm sure it will break in some catastrophic way at an inoportune moment, but it's been run pretty hard so far and is still holding up.
    I run randys yukon 4340 axles, and the jantz super joints. Also I was pretty cautious when I adjusted the stops, any joint that binds will break. /forums/images/graemlins/dunno.gif
  10. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Who's your photographer? Nice action shot. And if I must say so a good looking 10 bolt too. Not to fond of those steering stabilizers though........... /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
    BTW I ran 35's on my 10 bolt for 2 years now and beat the piss out of it on our last outing and held up fine. Especially when the axle tube somehow got hung up on a rock and had to scrape it off /forums/images/graemlins/thinking.gif Oh and the time my front tire come off the ground under hard acceleration and come down and caught a rock, still worked. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  11. 80blackgmc
    Nov 21, 2004
    43
    I think the good axles are the trick...i got stockers only for now, got two spares. Still though, I think something wasn't right. Was the same, long axel both times...
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I bet it was those factory u-joints you left in there that broke and took something else out. Go and get some new SPICER u-joints.
  13. 80blackgmc
    Nov 21, 2004
    43
    First time, exactly...second time no, axle broke inside the housing. One of the junkyard diffs I got has spicer u-joints. Not sure what kind of new ones I got with the bearing kit. I'll get some spicers. Anything better?
  14. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Factory u-joints were Spicer 297x. There is a new Spicer "life searies" joint out there that is said to be 30% stronger...I can't remember the # off hand but if you did a search for "297x" I'm sure it would come up. There is stronger out there but the new spicers will be stronger then the factory shafts.
  15. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can definitly break it with a 35" tire. We just got back from Parker AZ and we had 2 1/2 ton casualites. DJ wasted a short side ujoint and destroyed both inner and outer shafts. Rob (TheRobZilla) we are pretty sure wasted his ring and pinion gears. Rob runs 35" MTR's with Chromo's and CTM's (because he was tired of breaking axles) and DJ runs 36" IROK's with stock axles.
    Harley
  16. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am running chromos and ctms, after that you start to break R&P. So far I have had to replace the R&P once. That was broke before I bought it though(Sub on 37's"). It also helps having an ARB since you can turn the locker off when you don't need it. My bud just put 36" swampers on his 10 bolts. I told him to invest in some spare shafts /forums/images/graemlins/grin.gif Oh well I guess you just have to try it and see what happens /forums/images/graemlins/thinking.gif
  17. 80blackgmc
    Nov 21, 2004
    43
    Well, I don't take it off road that much, which pisses me off, because I would like to. But the junk brakes easy on me...I hate replacing that R&P even once, but its getting to be winter outside, and I want 4wd...
    Dana 60 is a must, if I wanna take this thing off road... /forums/images/graemlins/angryfire.gif
  18. dvldog 70k5
    Nov 7, 2004
    38
    So Cal, West Coast
    So what can someone expect to pay for a dana60 used. I mean I dont have a clue on what they would cost or how hard they are to install. Also, will the lift that I have now on my blazer work if I got a new dana60?
    Nick
  19. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It will all bolt on if you get the u-bolts and u-bolt plates with the axle (and if you already have 8-lug wheels).
    I got mine for $750 which is a good deal around here. It took me 2 years of searching to find it. Average price is more around $1000 and up. It would take ALOT of broken axle shafts (at $15-$30 a side for used + new u-joints at $30) and R&P's to add up to the cost of a D60!
    Keep the tires 35" or smaller, don't put a locker up front, put in new Spicer u-joints (and replace them every year or 2), and don't drive it like a complete idiot and you will be fine.
  20. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Well where's the fun in that /forums/images/graemlins/grin.gif /forums/images/graemlins/whistling.gif
