Dana 44 and Corporate 12 bolt..One in the Same??
Discussion in 'The Garage' started by equalizer, Oct 24, 2004.
  1. equalizer
    equalizer Registered Member
    Oct 13, 2003
    35
    Currently in Northern Alberta. Soon to be heading
    Hey guys, I was going through the LCm truck cataloge and just had a question. I ve got a 72 blazer, and what I was wondering was why did Chevrolet not opt for putting the Dana 44 axle in the rear of 4x4, just the front. Is the Corp 12 bolt and Dana 44 one in the same. Any ideas would put the issue to rest
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    They are not the same axle.
    Older rigs like Cornbinders and such had D44 rear axles.
    As to why.. the 12 bolt was pretty much the norm in light GM rigs as the Ford 9" is to their line up.
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    GM did use some dana 44 axles in the rear of some of their 4x4's, but they saw very limited use (much like the semifloating dana 60 rearend that some half ton 2wds had).
    I have seen 3-4 '67 and '68 GMC 1/2 ton 4x4's with a rear d44 from the factory. Never a Chevy, though, and only those 2 years. /forums/images/graemlins/dunno.gif
  4. Josh Northrup
    Josh Northrup Registered Member
    Feb 18, 2016
    5
    What rear-end would on my 88 k5 would it be a 12 bolt
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    No 12 bolt was phased out in the late 70s.
    From then on it was a 10 bolt
  6. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    71
    Humboldt/Pacifica, CA
    Unless someone put a different axle under it at some point. Just count the number of bolts on the diff cover.
  7. sreidmx
    sreidmx Fortify Offroad Vendor
    Oct 24, 2013
    4,807
    2,724
    Morongo Valley Ca
    I thought the 12 bolt had a larger ring gear??
  8. bent72
    bent72 Desert Solitaire Premium Member GMOTM Winner
    Dec 3, 2002
    7,868
    6,595
    colorado
    Slightly. Different sizes clear through on stuff. Nothing of super consequence or usefulness though
    sreidmx likes this.
  9. sreidmx
    Oct 24, 2013
    4,807
    2,724
    Morongo Valley Ca
    So whats the big deal about 10 bolt vs 12? is the axle larger or bearings?? semifloat?? what?
  10. bent72
    Dec 3, 2002
    7,868
    6,595
    colorado
    10 bolts die easier, but axle and bearing sizes are comparable.
    Both sf
  11. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    The 12 bolt pinion is actually smaller at the bearing I.D. I believe,so many claim they are no better (and maybe weaker) than a 10 bolt,for that reason...
    That said,I had 3 of the 12 bolt rears under 70's GM trucks and had zero problems,other than one stripping the pinion yoke splines out,which was my fault for doing burnouts in 4 low without locking the front hubs..:blush:..
    My '85 Burb has a 12 bolt rear,and as far as I can determine,its original to the truck--I've seen some other 1/2 tons with a 12 bolt from 1980-86 "factory",so I think GM used up what they had left over,after the supposed "cut off date" of 1980 or so..
  12. warrpath4x4
    warrpath4x4 1/2 ton status Premium Member
    May 8, 2010
    704
    60
    Prosser, WA
    I had an 87 Chevy 1/2 ton 4x4 and it had a 12 bolt rear from the factory
