Dana 44 axle diameter/ ubolt size??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Convertiyota, Aug 27, 2001.
  1. Convertiyota
    Convertiyota Registered Member
    Aug 20, 2001
    36
    Stafford, VA
    Need to know what size ubolts to get for the front. Are they 3" like the 12 bolt?? Thanks
    Check out the Convertible Yota
    http://www.100megspopup.com/tachnem
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Three of them are 3" and the other one that goes under the pumpkin is about 3 3/8".
    Tim
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI there are at least two different axle tube diameters for GM Dana(Spicer) 44's !
    If memory is working it like 2 5/8", and 3".
    Also as noted the one u-bolt that goes over the diff. is slightly larger(1/4").
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    On the 'first design' axles - '73 to '76, the front D44 tubes are 2 3/4" outside diameter.
    The 'second design' axles - '77 to '91, both D44's and 10B's are 3" diameter tubes.
    All the u-bolts that go around the differential housing part (the 1 bigger u-bolt) are a 3 5/8" diameter.
    So, you need 3 u-bolts at either 2 3/4" or 3" depending on what 'design' axle you have, and 1 u-bolt, 3 5/8" to fit the passenger side differential.
    <font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  5. Convertiyota
    Aug 20, 2001
    36
    Stafford, VA
    Can I get a 2nd vote for the size that goes over the diff housing?? We've got 3 3/8, 3 5/8, and 1/4" larger!!!!!!! Thanks ya'll.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Trust me on that measurement I gave you!!
    I got the measurements from my Superlift catalog!! [​IMG] Since when has Superlift ever been wrong?
  7. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    Wes is right. I just measured an old U-bolt from my old 10 bolt and it measured 3 5/8. The others measured 3".
    <font color=red>"Wheel hard or go home."</font color=red>
    click to see <a target="_blank" href=http://www.off-road.ws/images/users/BOWTIE/bowtie5.jpg> BOWTIE</a>
