dana 44 axle ujoints
Discussion in 'The Garage' started by alf4444, Jan 13, 2005.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Looks like I need to replace mine but here lies the question which ones to get CTM, OX, or are spicers good enough I'm thinking ox for the price but???
    Who has the best price on these?
  2. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    Tough call! I just put CTM's with Warn axles in my d44 with 8 lug conversion. Serious $$ though. ( screw retirement anyway:D ). Just decided I'd rather not take the time to replace them on some muddy trail somewhere! I figure with 37's they should hold up OK if I don't go too crazy with the right foot. However, I don't have any experience with OX either.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What is your setup on your truck?
    I say run Spicer 5-760x ujoints. They are the strongest factory ujoint on the market beside the custom stuff (CTM, OX, etc). As long as you aren't abusing your truck you should be ok. The cost of a CTM or OX is not justified if you are running stock axleshaft.
    I am running 35" tires and I rock crawl my K5 and they are holding up fine for me sofar (knock on wood). I have a lightish driving style though. I have seen 760's break on a truck with 36" tires and a heavier driving style in the rocks.
    Harley
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    OX is out. Pirate had a link to their estate auction. Don't know why but I don't think they will be able to replace any joint for a while (as in not making any more). CTM's are only complimented by superiors anything less will become a weak link and kill the CTM in the process. I am a fan of the new cold forge spicer stuff (760's) myself. If you are going to run stock shafts that is the ticket.
  5. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    D44 Joints
    Look into the Yukons....(Randy's Ring & Pinion)
    I just bought a pair, but have yet to install them...
    Time will tell.:dunno:
    Marv
  6. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    I ordered spicers to get me by for now!
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have an ox ujoint and a ctm u joint on my D44. Here is the problem that lies within. I have chromoly front shafts and an ARB locker. All strong components. Now where does the weak link lie? Your Ring and Pinion is the answer. The R&P was destroyed when I bout the axle (Dana parts). So if I were to do it all over again I would go with a spicer, that way it usually will break before evrything else does, usually.....You can by at least 6 front spicers for the price of one ctm. Just some food for thought:)
  8. clstolten
    clstolten 1/2 ton status
    Sep 4, 2002
    356
    Right on Stallion85. Keep the weak link at an easily replaceable part. The spicer u-joint has got to be your best choice. Next choice is Dana 60 in my opinion.
  9. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    Working on the d60:D
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you are running Chromoly axleshafts you should run CTM or Ox joints. If you break a standard joint in a Chromoly axle you will likely turn the axle into junk too, and they manufacturer will not warranty it. So you are then with left with an expensive piece of Chromo trash because you didn't use the good ujionts with the good axles.
    Harley
  11. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I've got CTM's with my superior axles in my D60. They have held up so far. If you are running stock axles,I'd go with the cold forged spicer Ujoints. You can get either of these from ORD.
