Dana 44 axles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Nov 30, 2000.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Its going to be a reallll long time before I swap out to 1-ton axles, so I want to make my Dana 44 strong enough to last until then. So far it has new ring and pinion gears, bearings, seals and Warn hubs. I was considering doing the axle shafts too. I saw that Moser just came out with some 44 axles and Warn does the expensive chromemoly ones. What have you guys done???
    '73 K5
    Chevy good...Ford bad
  2. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    How much are you spending on all these upgrades? Seems like alot of $$$ going into an axle your not going to keep. I have talked to a few local wrecking yards, and it seems that most of them will them(if they have one in stock)for around $1100-1300. That can't be far off your upgrade #'s. Just curious, not critical. I have the 3/4 ton d44 now, but would love to upgrade myself!
  3. '73 K5
    1,763
    Kansas
    I'm going to keep the axle, just not forever. I'm talking in between 2-3 years, since I have new 6 lug, 15 inch wheels, tires, etc. And the junkyards here suck for trying to find Dana 60's.
    '73 K5
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    ORD has the chromoly axles with lifetime warranties. These would probably be your best bet.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
  6. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The upgraded moly shafts run about $500. Just save that $500 for your Dana 60, which won't be too much more.
    ken
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Or just carry a couple of spares. You can pick 'em up cheap if you shop around a bit. Unless you're beating the bejeezus out of your truck, broken axle shafts should be few and far between.
    One idea is to buy a couple of spare shafts, then install them in your driveway to make sure they fit. Then just carry your old ones as spares, because you know they'll fit if one breaks out in the middle of east nowhere! [​IMG]
    http://ThunderTruck.ColoradoK5.com
