dana 44 brake lines
Discussion in 'The Garage' started by blazd88, Aug 20, 2004.
  1. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    what kind of brake line do i need for a dana 44 with 8 lugs? i just converted but have no brake lines and my original lines dont fit the new calipers.
    thanx /forums/images/graemlins/dunno.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If your old ones are from your 88 1/2ton 10bolt, then no, they won't fit a D44 cause of the banjo bolt difference. You have 2 choices here, go out and buy some new brake lines for a D44 caliper or just swap over your 10bolt calipers onto the D44 /forums/images/graemlins/thumb.gif
  3. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    So the calipers will swap????
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Yes. The only difference is the brake line fitting (10mm for a 10B and 3/8" for a D44).
  5. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I've got some lines if you need em..... somwhere...... in the shop....... I think......
  6. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    looks like im going to have to buy new extended line anyhow if anyone has any of those. this little stuff just for swapping in a 14 bolt and dana 44 outers is nickel and diming me to death. /forums/images/graemlins/screwy.gif
