Dana 44 Cross over steering...
Discussion in 'The Garage' started by BlackDog714, Jan 17, 2004.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    OK, so I was looking in the ORD page and I found this pic:
    I have a large hub Dana 44 that is flat on top, but it is not drilled for any mounting bolts. Do you have to drill and tap the top of the spindle? Is there a spindle that is already tapped?
    I want to do a crossover now so I dont have that expense when I put a Dana 60 in later.
  2. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Yes, you will have to have the hub drilled and tapped. ORD does it for $70.
    But I belive some of the components, like sterring arm and crossover arm will all be different with the D60, I'm not positive though.
    I too am embarking on the quest for crossover and just got my D44 knuckles, need to get them machined now for the crossover steering arm.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you can find higher steer knuckles than that, those are medium high ones there, but i guess it dpeends on how high of TRE's you want really
    good luck
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    There are a number of people including myself. The flat top knuckle is the knuckle that is on the right side of that pic. But yes, to answer you question, someone has to machine the top of the knuckle FLAT and drill and tap it for a steering arm.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    When I did my 10 bolt(same as d44) I had a local machine shop mill the top of the knuckle flat, drill and tap for me. Cost me 30.00.
  6. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    yup have to drill and tap it.
    Had a buddy do mine and make a arm from 1" stock. cheap and works like a hot damn! /forums/images/graemlins/rotfl.gif
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That is a damn good price!
