Dana 44 Crossover Parts!!!
Discussion in 'Parts & Trucks Wanted' started by Waxer, Aug 3, 2003.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    What does anyone have out there? I need all parts including passenger side steering arm, drag link, pitman arm, and possibly drilled/tapped pass side knuckle.
    Let me know. Thanks..
  2. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Hi
    I have a complete cross over/high steer set up. Includes D44 flat tops, with machine work done by ORD. ORD top knuckle arms. Tie rod uses TREs with stabalizer TRE fliped to pass side and drilled 3/4 for heim. Drag link is 1 1/4 c-molly with 3/4 heims. drop pitman arm is YJ application also drilled out for heim.
    550 plus shipping. I also have 8 lug hubs.
    Russ
    russrosevassar@yahoo.com
  3. Trevor
    Trevor 1/2 ton status
    Mar 10, 2002
    160
    Auburn, Ca
    I have everthing you need, all new.
    Passenger flattop knuckle, machined $150
    CNC machined steering arm with 1"spacer, 3 1" over studs $125
    1.25 diameter Draglink bent to miss crossmember with 7/16-18 threads to accept 1 ton draglink ends $75
    Ford/jeep style heavy duty pitman arm reamed to accept 1 ton chevy ends. $70
    Total, $420. You can use your factory draglink ends and cones and nuts. You will also need a 2 wheel drive box. Pm if interested.
