Dana 44 flat top knuckle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zepplin, Feb 25, 2003.
  1. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I'm looking in doing crossover steering on my 8 lug 10 bolt until I can afford a Dana 60.
    1) Can a flat top Dana 44 knuckle fit on a 10 bolt?
    2) Does anyone have one for sale that is already drilled for cross over steering?
    3) Other than a link from the steering box to the knuckle, what else would I need? (I have a 2wd steering box.)
    Thanks,
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    1- yes
    2- I don't
    3- you will need the arm that bolts to the flat top knuckle.
  3. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    Anyone have a knuckle available for sale?
  4. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    you need a ford dropped pitman arm also
    -Scott
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Don't have one that's already drilled, but have one. And you might not need a dropped arm, depending on the lift.
  6. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I think you have to swap both knuckles, pass and driver side. I was talking to Mudzer about this swap and he mentioned that you must swap both, but I forget why.
  7. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    you have to swap both since the tie rod on the flat top is mounted above the knuckle, where-as the 10 bolts tierod was mounted underneath the knuckle.
