Dana 44 flat top questions again....
Discussion in 'The Garage' started by TxK5Blazer, Mar 11, 2004.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I recently got the run around from a guy that I bought these flat top knuckles from. What I got is a set of Jeep Dana 44 flat tops and I want to know will they work on my 10bolt. I mean will the ball joints work on my 10bolt I will have to go hi steer because of the way the tie rod mounts but no biggie well thanks for the help guys ....Jason
  2. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    I think they will, to check get ahold of a parts store and find out the part # for the Jeep 44 ball-joints and the 10 bolt ball-joints and see if there the same #.
    HTH
  3. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
  4. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    I got a set off a dodge d44 and they are the same ball joints as my 10bolt.
    ~Jason
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Everything from the knuckle out on chevy D44's and 10 bolts interchange.
  6. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I know that but these came off a jeep dana 44. I guess what I want to know is, is a dana 44 a dana 44 no matter what the came off of ......Jason
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I got mine off a cheerokee and according to autozones web site mine use the same ball joints as a Chevy. The also look identical except the flat top and the tie rod mounts from the top /forums/images/graemlins/peace.gif
  8. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    that is just the info I needed thanks a bunch I am so happy to be a member here....Jason
