Dana 44 flat top w/bottom mount tie rod?
Discussion in 'The Garage' started by 88K5Jimmy, May 24, 2004.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    So I'm researching for my 10 bolt crossover and everything I have read so far states the tie rod mounts from the top on Dana 44 flat top knuckles. My tie rod mounts from the bottom on my 10 bolt. Did they make Dana 44 flat top knuckles where the tie rod mounted from the bottom? If not will I be able to use my current tie rod by flipping it?
    Also, when I switch knuckles can I reuse the balljoints because they are only a year old?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Re: Dana 44 flat top w. bottom mount tie rod?
    They didn't make them that I know of or have seen. I am gonna flip my tie-rod so I hope that works. /forums/images/graemlins/waytogo.gif
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    To the best of my knowledge(but i've been known to be wrong)all D44 flat tops are top mount. And yeah, I believe you can just use your current tie rod in one.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You should be able to just flip your tierod. I did when I did crossover on 10bolt front.
    Beware though that you need to install the tierod before you get the knuckles mounted in place though. The tierod won't fit in from the top with a flat tierod. The springs interfer. I almost found out the hard way. If I didnt have a 1" zero rate in my front spring packs it wouldn't have fit in. Mine BARELY fits.
    The other option is to use the special tierod ends for the top mount tierods. They are drop ends.
    Harley
  5. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    when I went to cross over the factory tie rod was way to long. I ended up making an entirely new tie rod. I switched axles but I don't see how that would have changed anything. Same width axles so it must have been all in the knuckle. That was just the experience that I had with this switch. You may get luckier than me.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im researching this, can i have the d44 knuckle reamed for the bottom mount tie rod?
    harley, you have your tie rod mounted under on driver side and over on pass side? any problems with that?
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I used to have my tierod from the bottom with my 10 bolt knuckles. Now with the D44 flattop knuckles it is a top mount.
    The only way to get the tierod from the bottom with flattop is to have the knuckles brazed up and rereamed from the bottom. It is up to you on how to mount it. If you can get the braze and ream done for a decent price for good work then I think it is worth it. Makes life alot easier on the tierod mount and spring interference.
    Harley
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I had no problems when I had my flat top D44. I did have shims though so they may have made the clearence difference. If you run a zero-rate I don't see it being a problem.
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    With my rock rod 1.5" OD and my #2234 RH ends my tierod BARELY fits into the knuckle holes. The rod contacts my springs (with a zero rate). I have to put on TRE in the hole then to get the other in I have to push the TRE all the way to one side and force it a little to get in the hole. /forums/images/graemlins/dunno.gif
    Harley
  10. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I never did get a rockrod (or any heavy duty one) for my D44.
    Harley:
    I guess we'll find out when jay gets a rockrod for my old axle /forums/images/graemlins/dunno.gif /forums/images/graemlins/whistling.gif
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Wow, I have major room with mine /forums/images/graemlins/dunno.gif
  12. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    So is the tie rod mounting location the same on bottom mount 10-bolts and top mount Dana 44s in regards to placement on the knuckle?
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    What inch lift springs are you running? I am only running a set of 4" TC's and I have a Warn M12000 that helps drag the front down a little.
    Harley
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    4" Ranchos and a heavyass 8274 and hella bumper.
  15. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    4" Ranchos and a heavyass 8274 and bumper.
