Dana 44 front axle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Biguub91, Dec 15, 2002.
  1. Biguub91
    Biguub91 Registered Member
    Nov 25, 2002
    33
    Texas
    i have a 91 K5 blazer and the front end looks like a dana 44. My friend said that some of them came with 44's. The guy from randy's ring and pinion told me they all had corporate 10-bolts. According to my axle guide it is nothing like a corporate 10-bolt and looks alot like a Dana 44. Anyone got any advice? I would also appreciate any help you have on identifying axles (i.e.- websites with serial numbers or where to find serial numbers on the axle)
  2. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    If it's a D44 it will be stamped on the lower right of the 3rd member housing. It might say D44F or something like that. My 1990 has a corp 10 bolt in the front.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    It should be a 10 bolt unless someone else has swapped in a D44.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sounds like the D44 was swapped into your Blazer. /forums/images/graemlins/eek.gif Nothing surprising as everyone is swapping axles, etc.
    The D44's last year in the Chevy line of trucks was in '80.
    The GMC line ran them up to '82 and then went 10 bolt full time like Chevy's did.
  5. Biguub91
    Nov 25, 2002
    33
    Texas
    when you said lower right side did you mean drivers or passenger? The drivers side says GM8 on the driveshaft side of the housing on the passenger side it says 14030378.
  6. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Driver's side. If you are looking at the front of the truck it will be on the bottom right of the 3rd member housing. To the bottom right of the differential cover.
  7. Grim-Reaper
    7,385
    Atlanta
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If it says GM8 its a 10B. Look at the guide Grim posted, if it doesn't look like the Dana cover its a 10B. The pic in that guide is not of a front 10B so your's will not look exactly like it.
  9. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    10bolts are round d44's arnt d60's look kinnda like a 44 but HUGE
