Dana 44 Front pinion seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zepplin, Nov 9, 2000.
  1. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    My front axle is leaking gear oil. To replace the pinion seal do you have to take out the pinion gear or do you simply remove the front yoke to replace the seal? I need to replace the seal before winter comes it leaks real bad.
    Communication Breakdown
    74 Blazer
    Zeppelin
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You just have to remove the yoke. I did this a few years ago, its not that hard, then again I had an impact.
    Rene
  3. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    Thanks alot. I didn't feel like taking out the carrier, etc. anyway. Thanks again.
    74 Blazer
    Zeppelin
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I also used a small 2 jaw puller to get the old seal out, if I remember right. Mine was in there pretty good. But I must have done something right because it still doesn't leak[​IMG]
    Rene
  6. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    Thanks, I'll see if I can rig something up to get it out. Thanks for all the help, everyone.
    74 Blazer
    Zeppelin
  7. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I just did both front and rear pinion seals. I didn't have an impact wrench, so I used a very large cresent wrench to hold the yoke while loosening the pinion nut. Also mark the nut, pinion shaft and yoke with paint and retorque to those marks during assembly. I read that if you overtighten the nut you can squash the crush sleeve on the pinion shaft. Have fun.
  8. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    To get the seal out, you can use a large pry bar and stick it in sideways and pry it out. This will destroy the old one but thats ok.
    Shawn
    87 K5
    few mods[​IMG]
  9. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    I appreciate all the help. I wasn't sure what I was getting into but, I know I can install the new seal without regreting anything.
    74 Blazer
    Zeppelin
