DANA 44 Gearing Question
Discussion in 'The Garage' started by rust bucket, Dec 9, 2005.
  1. rust bucket
    rust bucket Registered Member
    May 16, 2005
    5
    myrtle beach, sc
    I've got a 72 Blazer that has 3.07 gears. I want to build this blazer just for off road use only. I have a set of axles in a 72 3/4 ton truck (D44/Eaton) that are in fair shape, but I know the front axle needs new carrier bearings. Not sure about the rear yet, but they both have 4.10s. I also have a donor 1 ton Eaton for the rear that is in great shape with 4.56s.
    My question is, can I regear the 4.10 44 to 4.56, or does it take a new carrier. I was assuming the 3.07 axle would require a new carrier, but I am new to axle swaps like this and I need help.
    I am on a budget, or else I would look for a 60, but I am also not that hardcore, just mainly want larger tires and need the gearing to run them and I have all these axles handy and own them already.
    Any help is greatly appreciated.
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i can't answer your question about the carrier, but if it were me, i'd just find another 44 to run with your eaton. i've found its cheaper/easier that way.
    colby
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I believe the carrier break is 3.73 and down, and then 3.92 and up. If I am not smoking too much crack, you should be good to go.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That is correct sir!:D
  5. rust bucket
    May 16, 2005
    5
    myrtle beach, sc
    Thanks to everyone for the quick replies. I want to start this project over Christmas break.
